- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
If you use a proxy setup, you may run into issues when trying to launch Automation Hub and Apps.
Solution
You can fix the issue by taking the following steps:
Capture the existing
corednsconfigmap from the running cluster:kubectl get configmap -n kube-system coredns -o yaml > coredns-config.yamlkubectl get configmap -n kube-system coredns -o yaml > coredns-config.yaml -
Edit the
coredns-config.yamlfile to append thefqdnrewrite to the config.Once you have completed these steps, your file should resemble the following sample:
apiVersion: v1 data: Corefile: | .:53 { errors log health rewrite stop { name exact mycluster.autosuite.com istio-ingressgateway.istio-system.svc.cluster.local } kubernetes cluster.local in-addr.arpa ip6.arpa { pods insecure fallthrough in-addr.arpa ip6.arpa } prometheus :9153 forward . /etc/resolv.conf cache 30 loop reload loadbalance } kind: ConfigMap metadata: name: coredns-custom namespace: kube-systemapiVersion: v1 data: Corefile: | .:53 { errors log health rewrite stop { name exact mycluster.autosuite.com istio-ingressgateway.istio-system.svc.cluster.local } kubernetes cluster.local in-addr.arpa ip6.arpa { pods insecure fallthrough in-addr.arpa ip6.arpa } prometheus :9153 forward . /etc/resolv.conf cache 30 loop reload loadbalance } kind: ConfigMap metadata: name: coredns-custom namespace: kube-system-
Rename the configmap to
coredns-custom. -
Add the following code block to your
coredns-config.yamlfile. Make sure the code block comes before thekubernetes cluster.local in-addr.arpa ip6.arpline.rewrite stop { name exact <cluster-fqdn> istio-ingressgateway.istio-system.svc.cluster.local }rewrite stop { name exact <cluster-fqdn> istio-ingressgateway.istio-system.svc.cluster.local } -
Replace
<cluster-fqdn>with the actual value.
Create the
coredns-customconfigmap:kubectl apply -f coredns-config.yamlkubectl apply -f coredns-config.yaml -
Replace the volume reference from
corednstocoredns-customin thecorednsdeployment inkube-systemnamespace:volumes: - emptyDir: {} name: tmp - configMap: defaultMode: 420 items: - key: Corefile path: Corefile name: coredns-custom name: config-volumevolumes: - emptyDir: {} name: tmp - configMap: defaultMode: 420 items: - key: Corefile path: Corefile name: coredns-custom name: config-volume -
Restart the
corednsdeployment and ensure thecorednspods are up and running without any issues:kubectl rollout restart deployment -n kube-system corednskubectl rollout restart deployment -n kube-system coredns -
You should now be able to launch Automation Hub and Apps.
