- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Applying a patch
An Automation Suite patch is an update to an existing version, which addresses bugs or security vulnerabilities. For instance, patch 2022.10.14+patch1 addresses issues impacting version 2022.10.14.
Instead of applying the patch, we recommend upgrading to the Cumulative Update (CU) that contains the same fix. All fixes provided in patches will also be available in the CU mentioned in the release notes for the patch.
To apply a patch to an existing Automation Suite version, take the following steps:
Update the registry with the latest images.
- Download the following patch artifacts from Patch artifact download links. Choose the set of artifacts applicable to your patch and registry configuration type.
sf.tar.gz- Any optional Document Understanding or Computer Vision bundle, if needed.
- For offline, take the following steps:
Make sure that
sf.tar.gzis available in the/uipath/tmpfolder. Run the following commad:./configureUiPathAS.sh registry upload --offline-bundle "/uipath/tmp/sf.tar.gz" --offline-tmp-folder "/uipath/tmp"./configureUiPathAS.sh registry upload --offline-bundle "/uipath/tmp/sf.tar.gz" --offline-tmp-folder "/uipath/tmp" -
Load the optional bundles:
To load the optional Document Understanding bundle, run the following command:
./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/du-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp"./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/du-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp" -
To load the optional Computer Vision bundle, run the following command:
./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/cv-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp"./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/cv-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp"
Download
versions.json. For instructions, see Patch artifact download links. -
Apply the patch by running the following command:
./install-uipath.sh --patch /tmp/versions.json --install-type <INSTALL_TYPE> -i ./cluster_config.json -o ./output.json -s --accept-license-agreement./install-uipath.sh --patch /tmp/versions.json --install-type <INSTALL_TYPE> -i ./cluster_config.json -o ./output.json -s --accept-license-agreementReplace
INSTALL_TYPEwith the applicable value:offlineoronline. -
Check if the patch operation was successful by taking the following steps:
Run the following command to list the versions of all services:
kubectl -n argocd get application -o widekubectl -n argocd get application -o wide -
Verify that the versions of the patched services are updated.
