- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Package |
Purpose |
UiPath.OrganizationMigrationApp |
-O parameter.
installUiPathAS.sh is an interactive installer wizard that you can use to accept the installation configuration and start the installation.
installUiPathAS.sh is required for both online and offline installation profiles and is used during a fresh installation and for adding a new
node to the cluster.
2022.10.15
https://download.uipath.com/automation-suite/2022.10.15/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.15/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.15/installUiPathAS.sh -
Windows:
To downloadinstallUiPathAS.shon a Windows machine, click here.
2022.10.14
https://download.uipath.com/automation-suite/2022.10.14/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.14/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.14/installUiPathAS.sh -
Windows:
2022.10.13
https://download.uipath.com/automation-suite/2022.10.13/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.13/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.13/installUiPathAS.sh -
Windows:
2022.10.12
https://download.uipath.com/automation-suite/2022.10.12/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.12/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.12/installUiPathAS.sh -
Windows:
2022.10.11
https://download.uipath.com/automation-suite/2022.10.11/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.11/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.11/installUiPathAS.sh -
Windows:
2022.10.10
https://download.uipath.com/automation-suite/2022.10.10/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.10/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.10/installUiPathAS.sh -
Windows:
2022.10.9
https://download.uipath.com/automation-suite/2022.10.9/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.9/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.9/installUiPathAS.sh -
Windows:
2022.10.8
https://download.uipath.com/automation-suite/2022.10.8/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.8/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.8/installUiPathAS.sh -
Windows:
2022.10.7
https://download.uipath.com/automation-suite/2022.10.7/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.7/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.7/installUiPathAS.sh -
Windows:
2022.10.6
https://download.uipath.com/automation-suite/2022.10.6/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.6/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.6/installUiPathAS.sh -
Windows:
2022.10.5
https://download.uipath.com/automation-suite/2022.10.5/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.5/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.5/installUiPathAS.sh -
Windows:
2022.10.4
We removed the Automation Suite 2022.10.4 installation packages due to a major bug affecting Automation Ops. We recommend upgrading to Automation Suite 2022.10.5 instead, which includes a bug fix for Automation Ops.
2022.10.3
https://download.uipath.com/automation-suite/2022.10.3/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.3/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.3/installUiPathAS.sh -
Windows:
2022.10.2
https://download.uipath.com/automation-suite/2022.10.2/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.2/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.2/installUiPathAS.sh -
Windows:
2022.10.1
https://download.uipath.com/automation-suite/2022.10.1/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.1/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.1/installUiPathAS.sh -
Windows:
2022.10.0
https://download.uipath.com/automation-suite/2022.10.0/installUiPathAS.sh
Linux:
To downloadinstallUiPathAS.shon a Linux machine, run the following command from the terminal:wget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.0/installUiPathAS.shwget -O ~/installUiPathAS.sh https://download.uipath.com/automation-suite/2022.10.0/installUiPathAS.sh -
Windows:
sf-installer.zip is an installation package that contains the main installation and supporting scripts.
sf-installer.zip. If you opt for the online installation profile, sf-installer.zip is automatically downloaded by the interactive installation wizard.
sf-installer.zip file is required during installation, upgrade, cluster restore in the event of disaster, and while adding new node to existing
cluster.
2022.10.15
https://download.uipath.com/automation-suite/2022.10.15/installer-2022.10.15.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.15/installer-2022.10.15.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.15/installer-2022.10.15.zip -
Windows:
To downloadsf-installer.zipon a Windows machine, click here and rename the file tosf-installer.zip.
2022.10.14
https://download.uipath.com/automation-suite/2022.10.14/installer-2022.10.14.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.14/installer-2022.10.14.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.14/installer-2022.10.14.zip -
Windows:
2022.10.13
https://download.uipath.com/automation-suite/2022.10.13/installer-2022.10.13.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.13/installer-2022.10.13.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.13/installer-2022.10.13.zip -
Windows:
2022.10.12
https://download.uipath.com/automation-suite/2022.10.12/installer-2022.10.12.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.12/installer-2022.10.12.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.12/installer-2022.10.12.zip -
Windows:
2022.10.11
https://download.uipath.com/automation-suite/2022.10.11/installer-2022.10.11.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.11/installer-2022.10.11.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.11/installer-2022.10.11.zip -
Windows:
2022.10.10
https://download.uipath.com/automation-suite/2022.10.10/installer-2022.10.10.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.10/installer-2022.10.10.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.10/installer-2022.10.10.zip -
Windows:
2022.10.9
https://download.uipath.com/automation-suite/2022.10.9/installer-2022.10.9.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.9/installer-2022.10.9.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.9/installer-2022.10.9.zip -
Windows:
2022.10.8
https://download.uipath.com/automation-suite/2022.10.8/installer-2022.10.8.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.8/installer-2022.10.8.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.8/installer-2022.10.8.zip -
Windows:
2022.10.7
https://download.uipath.com/automation-suite/2022.10.7/installer-2022.10.7.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.7/installer-2022.10.7.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.7/installer-2022.10.7.zip -
Windows:
2022.10.6
https://download.uipath.com/automation-suite/2022.10.6/installer-2022.10.6.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.6/installer-2022.10.6.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.6/installer-2022.10.6.zip -
Windows:
2022.10.5
https://download.uipath.com/automation-suite/2022.10.5/installer-2022.10.5.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.5/installer-2022.10.5.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.5/installer-2022.10.5.zip -
Windows:
2022.10.4
2022.10.3
https://download.uipath.com/automation-suite/2022.10.3/installer-2022.10.3.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.3/installer-2022.10.3.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.3/installer-2022.10.3.zip -
Windows:
2022.10.2
https://download.uipath.com/automation-suite/2022.10.2/installer-2022.10.2.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.2/installer-2022.10.2.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.2/installer-2022.10.2.zip -
Windows:
2022.10.1
https://download.uipath.com/automation-suite/2022.10.1/installer-2022.10.1.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.1/installer-2022.10.1.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.1/installer-2022.10.1.zip -
Windows:
2022.10.0
https://download.uipath.com/automation-suite/2022.10.0/installer-2022.10.0.zip
Linux:
To downloadsf-installer.zipon a Linux machine, run the following command from the terminal:wget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.0/installer-2022.10.0.zipwget -O ~/sf-installer.zip https://download.uipath.com/automation-suite/2022.10.0/installer-2022.10.0.zip -
Windows:
sf.tar.gz contains the container images and deployment manifests of UiPath Shared Capabilities and UiPath Product. The bundle is approximately
25 GiB in size.
sf.tar.gz. If you choose the online installation profile, Kubernetes will pull all the container images and deployment manifests directly
from the container registry hosted in UiPath servers.
sf.tar.gz is required during installation and upgrade only on server node when using internal Docker registry.
2022.10.15
https://download.uipath.com/automation-suite/2022.10.15/sf-2022.10.15.tar.gz
Checksum file available here.
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.15/sf-2022.10.15.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.15/sf-2022.10.15.tar.gz -
Windows:
2022.10.14
https://download.uipath.com/automation-suite/2022.10.14/sf-2022.10.14.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.14/sf-2022.10.14.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.14/sf-2022.10.14.tar.gz -
Windows:
2022.10.13
https://download.uipath.com/automation-suite/2022.10.13/sf-2022.10.13.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.13/sf-2022.10.13.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.13/sf-2022.10.13.tar.gz -
Windows:
2022.10.12
https://download.uipath.com/automation-suite/2022.10.12/sf-2022.10.12.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.12/sf-2022.10.12.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.12/sf-2022.10.12.tar.gz -
Windows:
2022.10.11
https://download.uipath.com/automation-suite/2022.10.11/sf-2022.10.11.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.11/sf-2022.10.11.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.11/sf-2022.10.11.tar.gz -
Windows:
2022.10.10
https://download.uipath.com/automation-suite/2022.10.10/sf-2022.10.10.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.10/sf-2022.10.10.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.10/sf-2022.10.10.tar.gz -
Windows:
2022.10.9
https://download.uipath.com/automation-suite/2022.10.9/sf-2022.10.9.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.9/sf-2022.10.9.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.9/sf-2022.10.9.tar.gz -
Windows:
2022.10.8
https://download.uipath.com/automation-suite/2022.10.8/sf-2022.10.8.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.8/sf-2022.10.8.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.8/sf-2022.10.8.tar.gz -
Windows:
2022.10.7
https://download.uipath.com/automation-suite/2022.10.7/sf-2022.10.7.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.7/sf-2022.10.7.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.7/sf-2022.10.7.tar.gz -
Windows:
2022.10.6
https://download.uipath.com/automation-suite/2022.10.6/sf-2022.10.6.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.6/sf-2022.10.6.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.6/sf-2022.10.6.tar.gz -
Windows:
2022.10.5
https://download.uipath.com/automation-suite/2022.10.5/sf-2022.10.5.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.5/sf-2022.10.5.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.5/sf-2022.10.5.tar.gz -
Windows:
2022.10.4
2022.10.3
https://download.uipath.com/automation-suite/2022.10.3/sf-2022.10.3.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.3/sf-2022.10.3.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.3/sf-2022.10.3.tar.gz -
Windows:
2022.10.2
https://download.uipath.com/automation-suite/2022.10.2/sf-2022.10.2.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.2/sf-2022.10.2.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.2/sf-2022.10.2.tar.gz -
Windows:
2022.10.1
https://download.uipath.com/automation-suite/2022.10.1/sf-2022.10.1.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.1/sf-2022.10.1.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.1/sf-2022.10.1.tar.gz -
Windows:
2022.10.0
https://download.uipath.com/automation-suite/2022.10.0/sf-2022.10.0.tar.gz
Linux:
To downloadsf.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.0/sf-2022.10.0.tar.gzwget -O ~/sf.tar.gz https://download.uipath.com/automation-suite/2022.10.0/sf-2022.10.0.tar.gz -
Windows:
sf-infra.tar.gz contains Kubernetes packages and other tools needed to install the cluster infrastructure.
sf-infra.tar.gz. If you opt for the online installation profile, the installer will pull these tools directly from UiPath trusted RPM registries.
sf-infra.tar.gz is required during installation, upgrade, cluster restore in the event of disaster, and while adding a new node to the existing
cluster.
2022.10.15
https://download.uipath.com/automation-suite/2022.10.15/sf-infra-only-2022.10.15.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.15/sf-infra-only-2022.10.15.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.15/sf-infra-only-2022.10.15.tar.gz -
Windows:
To downloadsf-infra.tar.gzon a Windows machine, click here and rename the file tosf-infra.tar.gz.
2022.10.14
https://download.uipath.com/automation-suite/2022.10.14/sf-infra-only-2022.10.14.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.14/sf-infra-only-2022.10.14.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.14/sf-infra-only-2022.10.14.tar.gz -
Windows:
2022.10.13
https://download.uipath.com/automation-suite/2022.10.13/sf-infra-only-2022.10.13.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.13/sf-infra-only-2022.10.13.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.13/sf-infra-only-2022.10.13.tar.gz -
Windows:
2022.10.12
https://download.uipath.com/automation-suite/2022.10.12/sf-infra-only-2022.10.12.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.12/sf-infra-only-2022.10.12.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.12/sf-infra-only-2022.10.12.tar.gz -
Windows:
2022.10.11
https://download.uipath.com/automation-suite/2022.10.11/sf-infra-only-2022.10.11.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.11/sf-infra-only-2022.10.11.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.11/sf-infra-only-2022.10.11.tar.gz -
Windows:
2022.10.10
https://download.uipath.com/automation-suite/2022.10.10/sf-infra-only-2022.10.10.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.10/sf-infra-only-2022.10.10.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.10/sf-infra-only-2022.10.10.tar.gz -
Windows:
2022.10.9
https://download.uipath.com/automation-suite/2022.10.9/sf-infra-only-2022.10.9.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.9/sf-infra-only-2022.10.9.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.9/sf-infra-only-2022.10.9.tar.gz -
Windows:
2022.10.8
https://download.uipath.com/automation-suite/2022.10.8/sf-infra-only-2022.10.8.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.8/sf-infra-only-2022.10.8.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.8/sf-infra-only-2022.10.8.tar.gz -
Windows:
2022.10.7
https://download.uipath.com/automation-suite/2022.10.7/sf-infra-only-2022.10.7.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.7/sf-infra-only-2022.10.7.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.7/sf-infra-only-2022.10.7.tar.gz -
Windows:
2022.10.6
https://download.uipath.com/automation-suite/2022.10.6/sf-infra-only-2022.10.6.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.6/sf-infra-only-2022.10.6.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.6/sf-infra-only-2022.10.6.tar.gz -
Windows:
2022.10.5
https://download.uipath.com/automation-suite/2022.10.5/sf-infra-only-2022.10.5.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.5/sf-infra-only-2022.10.5.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.5/sf-infra-only-2022.10.5.tar.gz -
Windows:
2022.10.4
2022.10.3
https://download.uipath.com/automation-suite/2022.10.3/sf-infra-only-2022.10.3.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.3/sf-infra-only-2022.10.3.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.3/sf-infra-only-2022.10.3.tar.gz -
Windows:
2022.10.2
https://download.uipath.com/automation-suite/2022.10.2/sf-infra-only-2022.10.2.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.2/sf-infra-only-2022.10.2.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.2/sf-infra-only-2022.10.2.tar.gz -
Windows:
2022.10.1
https://download.uipath.com/automation-suite/2022.10.1/sf-infra-only-2022.10.1.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.1/sf-infra-only-2022.10.1.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.1/sf-infra-only-2022.10.1.tar.gz -
Windows:
2022.10.0
https://download.uipath.com/automation-suite/2022.10.0/sf-infra-only-2022.10.0.tar.gz
Linux:
To downloadsf-infra.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.0/sf-infra-only-2022.10.0.tar.gzwget -O ~/sf-infra.tar.gz https://download.uipath.com/automation-suite/2022.10.0/sf-infra-only-2022.10.0.tar.gz -
Windows:
du-ondemand.tar.gz contains base images to install Document Understanding packages.
du-ondemand.tar.gz. If you choose the online installation profile, Automation Suite pulls all the Document Understanding base images directly
du-ondemand.tar.gz is required only when Document Understanding is installed.
For download instructions, see ML Packages Offline Installation.
du-ondemand.tar.gz.
cv-ondemand.tar.gz contains Computer Vision models and packages.
cv-ondemand.tar.gz. If you choose the online installation profile, Automation Suite will pull all the Computer Vision models directly from the
container registry hosted in UiPath® servers.
cv-ondemand.tar.gz is required only when you want to use Computer Vision models.
2022.10.15
https://download.uipath.com/automation-suite/2022.10.15/cv221009-2022.10.15.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.15/cv221009-2022.10.15.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.15/cv221009-2022.10.15.tar.gz -
Windows:
To downloadcv-ondemand.tar.gzon a Windows machine, click here and rename the file tocv-ondemand.tar.gz.
2022.10.14
https://download.uipath.com/automation-suite/2022.10.14/cv221009-2022.10.14.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.14/cv221009-2022.10.14.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.14/cv221009-2022.10.14.tar.gz -
Windows:
2022.10.13
https://download.uipath.com/automation-suite/2022.10.13/cv221009-2022.10.13.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.13/cv221009-2022.10.13.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.13/cv221009-2022.10.13.tar.gz -
Windows:
2022.10.12
https://download.uipath.com/automation-suite/2022.10.12/cv221009-2022.10.12.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.12/cv221009-2022.10.12.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.12/cv221009-2022.10.12.tar.gz -
Windows:
2022.10.11
https://download.uipath.com/automation-suite/2022.10.11/cv221009-2022.10.11.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.11/cv221009-2022.10.11.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.11/cv221009-2022.10.11.tar.gz -
Windows:
2022.10.10
https://download.uipath.com/automation-suite/2022.10.10/cv221009-2022.10.10.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.10/cv221009-2022.10.10.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.10/cv221009-2022.10.10.tar.gz -
Windows:
2022.10.9
https://download.uipath.com/automation-suite/2022.10.9/cv-2022.10.9.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.9/cv-2022.10.9.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.9/cv-2022.10.9.tar.gz -
Windows:
2022.10.8
https://download.uipath.com/automation-suite/2022.10.8/cv-2022.10.8.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.8/cv-2022.10.8.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.8/cv-2022.10.8.tar.gz -
Windows:
2022.10.7
https://download.uipath.com/automation-suite/2022.10.7/cv-2022.10.7.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.7/cv-2022.10.7.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.7/cv-2022.10.7.tar.gz -
Windows:
2022.10.6
https://download.uipath.com/automation-suite/2022.10.6/cv-2022.10.6.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.6/cv-2022.10.6.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.6/cv-2022.10.6.tar.gz -
Windows:
2022.10.5
https://download.uipath.com/automation-suite/2022.10.5/cv-2022.10.5.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.5/cv-2022.10.5.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.5/cv-2022.10.5.tar.gz -
Windows:
2022.10.4
2022.10.3
https://download.uipath.com/automation-suite/2022.10.3/cv-2022.10.3.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.3/cv-2022.10.3.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.3/cv-2022.10.3.tar.gz -
Windows:
2022.10.2
https://download.uipath.com/automation-suite/2022.10.2/cv-2022.10.2.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.2/cv-2022.10.2.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.2/cv-2022.10.2.tar.gz -
Windows:
2022.10.1
https://download.uipath.com/automation-suite/2022.10.1/cv-2022.10.1.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.1/cv-2022.10.1.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.1/cv-2022.10.1.tar.gz -
Windows:
2022.10.0
https://download.uipath.com/automation-suite/2022.10.0/cv-2022.10.0.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.0/cv-2022.10.0.tar.gzwget -O ~/cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2022.10.0/cv-2022.10.0.tar.gz -
Windows:
The UiPath.OrganizationMigrationApp tool helps you perform operations such as move the Identity data of all tenants from standalone to Automation Suite and merge organizations.
To check which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
2022.10.14
If you plan to migrate to Automation Suite 2022.10.14, use the following download links:
Linux
To download UiPath.OrganizationMigrationApp on a Linux machine, run the following command on the terminal:
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.10.14_Oct-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.10.14_Oct-linux.zip -
Windows
To download UiPath.OrganizationMigrationApp on a Windows machine, click here.
If you plan to migrate to Automation Suite 2022.10.13, use the following download links:
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.10.14_Aug-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.10.14_Aug-linux.zip -
Windows
2022.10.12
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.10.12-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.10.12-linux.zip -
Windows
2022.10.11
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.10.11-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.10.11-linux.zip -
Windows
2022.10.10
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.10.10-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2022.10.10-linux.zip -
Windows
2022.10.8
Linux
wget https://download.uipath.com/versions/22.10.8/MSIToAutomationSuiteTenantMigrator-2022.10.8-linux.zipwget https://download.uipath.com/versions/22.10.8/MSIToAutomationSuiteTenantMigrator-2022.10.8-linux.zip -
Windows
2022.10.7
Linux
wget https://download.uipath.com/versions/22.10.7/MSIToAutomationSuiteTenantMigrator-2022.10.7-linux.zipwget https://download.uipath.com/versions/22.10.7/MSIToAutomationSuiteTenantMigrator-2022.10.7-linux.zip -
Windows
2022.10.6
Linux
wget https://download.uipath.com/versions/22.10.6/MSIToAutomationSuiteTenantMigrator-2022.10.6-linux.zipwget https://download.uipath.com/versions/22.10.6/MSIToAutomationSuiteTenantMigrator-2022.10.6-linux.zip -
Windows
2022.10.5
Linux
wget https://download.uipath.com/versions/22.10.5/MSIToAutomationSuiteTenantMigrator-2022.10.5-linux.zipwget https://download.uipath.com/versions/22.10.5/MSIToAutomationSuiteTenantMigrator-2022.10.5-linux.zip -
Windows
configureUiPathDisks.sh to partition the disk before installation.
The latest version of the script works across all 2022.10.x versions of Automation Suite.
2022.10.15
https://download.uipath.com/automation-suite/2022.10.15/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.15/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.15/configureUiPathDisks.sh -
Windows:
To downloadconfigureUiPathDisks.shon a Windows machine, click here.
2022.10.14
https://download.uipath.com/automation-suite/2022.10.14/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.14/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.14/configureUiPathDisks.sh -
Windows:
2022.10.13
https://download.uipath.com/automation-suite/2022.10.13/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.13/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.13/configureUiPathDisks.sh -
Windows:
2022.10.12
https://download.uipath.com/automation-suite/2022.10.12/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.12/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.12/configureUiPathDisks.sh -
Windows:
2022.10.11
https://download.uipath.com/automation-suite/2022.10.11/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.11/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.11/configureUiPathDisks.sh -
Windows:
2022.10.10
https://download.uipath.com/automation-suite/2022.10.10/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.10/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.10/configureUiPathDisks.sh -
Windows:
2022.10.9
https://download.uipath.com/automation-suite/2022.10.9/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.9/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.9/configureUiPathDisks.sh -
Windows:
2022.10.8
https://download.uipath.com/automation-suite/2022.10.8/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.8/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.8/configureUiPathDisks.sh -
Windows:
2022.10.7
https://download.uipath.com/automation-suite/2022.10.7/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.7/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.7/configureUiPathDisks.sh -
Windows:
2022.10.6
https://download.uipath.com/automation-suite/2022.10.6/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.6/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.6/configureUiPathDisks.sh -
Windows:
2022.10.5
https://download.uipath.com/automation-suite/2022.10.5/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.5/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.5/configureUiPathDisks.sh -
Windows:
2022.10.4
https://download.uipath.com/automation-suite/2022.10.4/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.4/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.4/configureUiPathDisks.sh -
Windows:
2022.10.3
https://download.uipath.com/automation-suite/2022.10.3/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.3/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.3/configureUiPathDisks.sh -
Windows:
2022.10.2
https://download.uipath.com/automation-suite/2022.10.2/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.2/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.2/configureUiPathDisks.sh -
Windows:
2022.10.1
https://download.uipath.com/automation-suite/2022.10.1/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.1/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.1/configureUiPathDisks.sh -
Windows:
2022.10.0
https://download.uipath.com/automation-suite/2022.10.0/configureUiPathDisks.sh
Linux:
To downloadconfigureUiPathDisks.shon a Linux machine, run the following command from the terminal:wget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.0/configureUiPathDisks.shwget -O ~/configureUiPathDisks.sh https://download.uipath.com/automation-suite/2022.10.0/configureUiPathDisks.sh -
Windows:
supportability-tools works with all Automation Suite versions.
https://download.uipath.com/automation-suite/2022.10.14/supportability-tools-2022.10.14.zip
Linux:
To downloadsupportability-toolson a Linux machine, run the following command from the terminal:wget -O ~/supportability-tools.zip https://download.uipath.com/automation-suite/2022.10.14/supportability-tools-2022.10.14.zipwget -O ~/supportability-tools.zip https://download.uipath.com/automation-suite/2022.10.14/supportability-tools-2022.10.14.zip -
Windows:
To downloadsupportability-toolson a Windows machine, click here and rename the file tosupportability-tools.
objectstore-migration.sh helps you migrate Objectstore data in online and offline installations.
https://download.uipath.com/automation-suite/objectstore-migration.sh
Linux:
To downloadobjectstore-migration.shon a Linux machine, run the following command from the terminal:wget -O ~/objectstore-migration.sh https://download.uipath.com/automation-suite/objectstore-migration.shwget -O ~/objectstore-migration.sh https://download.uipath.com/automation-suite/objectstore-migration.sh -
Windows:
To downloadobjectstore-migration.shon a Windows machine, click here.
automation-suite-util.tar.gz helps you migrate Objectstore data in offline installations.
https://download.uipath.com/automation-suite/automation-suite-util.tar.gz
Linux:
To downloadautomation-suite-util.tar.gzon a Linux machine, run the following command from the terminal:wget -O ~/automation-suite-util.tar.gz https://download.uipath.com/automation-suite/automation-suite-util.tar.gzwget -O ~/automation-suite-util.tar.gz https://download.uipath.com/automation-suite/automation-suite-util.tar.gz -
Windows:
To downloadautomation-suite-util.tar.gzon a Windows machine, click here.
rke2-killall.sh on a Linux machine, run the following command from the terminal:
wget -O /usr/bin/rke2-killall.sh https://raw.githubusercontent.com/UiPath/automation-suite-support-tools/refs/heads/main/Scripts/GeneralTools/rke2-killall.sh
chmod +x /usr/bin/rke2-killall.shwget -O /usr/bin/rke2-killall.sh https://raw.githubusercontent.com/UiPath/automation-suite-support-tools/refs/heads/main/Scripts/GeneralTools/rke2-killall.sh
chmod +x /usr/bin/rke2-killall.sh/usr/bin/rke2-killall.sh.
- Overview
- installUiPathAS.sh
- 2022.10.15
- 2022.10.14
- 2022.10.13
- 2022.10.12
- 2022.10.11
- 2022.10.10
- 2022.10.9
- 2022.10.8
- 2022.10.7
- 2022.10.6
- 2022.10.5
- 2022.10.4
- 2022.10.3
- 2022.10.2
- 2022.10.1
- 2022.10.0
- sf-installer.zip
- 2022.10.15
- 2022.10.14
- 2022.10.13
- 2022.10.12
- 2022.10.11
- 2022.10.10
- 2022.10.9
- 2022.10.8
- 2022.10.7
- 2022.10.6
- 2022.10.5
- 2022.10.4
- 2022.10.3
- 2022.10.2
- 2022.10.1
- 2022.10.0
- sf.tar.gz
- 2022.10.15
- 2022.10.14
- 2022.10.13
- 2022.10.12
- 2022.10.11
- 2022.10.10
- 2022.10.9
- 2022.10.8
- 2022.10.7
- 2022.10.6
- 2022.10.5
- 2022.10.4
- 2022.10.3
- 2022.10.2
- 2022.10.1
- 2022.10.0
- sf-infra.tar.gz
- 2022.10.15
- 2022.10.14
- 2022.10.13
- 2022.10.12
- 2022.10.11
- 2022.10.10
- 2022.10.9
- 2022.10.8
- 2022.10.7
- 2022.10.6
- 2022.10.5
- 2022.10.4
- 2022.10.3
- 2022.10.2
- 2022.10.1
- 2022.10.0
- Du-ondemand.tar.gz
- cv-ondemand.tar.gz
- 2022.10.15
- 2022.10.14
- 2022.10.13
- 2022.10.12
- 2022.10.11
- 2022.10.10
- 2022.10.9
- 2022.10.8
- 2022.10.7
- 2022.10.6
- 2022.10.5
- 2022.10.4
- 2022.10.3
- 2022.10.2
- 2022.10.1
- 2022.10.0
- UiPath.OrganizationMigrationApp
- 2022.10.14
- 2022.10.12
- 2022.10.11
- 2022.10.10
- 2022.10.8
- 2022.10.7
- 2022.10.6
- 2022.10.5
- ConfigureUiPathDisks.sh
- 2022.10.15
- 2022.10.14
- 2022.10.13
- 2022.10.12
- 2022.10.11
- 2022.10.10
- 2022.10.9
- 2022.10.8
- 2022.10.7
- 2022.10.6
- 2022.10.5
- 2022.10.4
- 2022.10.3
- 2022.10.2
- 2022.10.1
- 2022.10.0
- Supportability-tools
- objectstore-migration.sh
- automation-suite-util.tar.gz
- rke2-killall.sh
