- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Migration prerequisites
Before starting the migration, make sure you meet the following prerequisites:
.NET Runtime 6.0
.NET Runtime 6.0 or later is required to run the UiPath.OrganizationMigrationApp tool. You must download and install it before running UiPath.OrganizationMigrationApp.
Linux
If .NET Runtime 6.0 or later is not present, download and install .NET Runtime for Linux before using UiPath.OrganizationMigrationApp.
To install .NET Runtime 6.0 on RHEL, run the following command:
sudo yum install dotnet-sdk-6.0 -y
Windows
The UiPath.OrganizationMigrationApp tool requires .NET Runtime 6.0 at a minimum. If .NET Runtime 6.0 and beyond is not present, download and install .NET Runtime 6.0 for Windows before using UiPath.OrganizationMigrationApp.
Orchestrator bucket creation setting
To ensure that Orchestrator buckets are automatically created with the correct CORS policy, you must run the following command. The command requires the jq utility to be installed on your machine.
cd <AS install directory>
rm -f values.json && rm -f appsettings.json
kubectl -n uipath get cm orchestrator-customconfig -o jsonpath='{.data.values\.json}' | jq '.' > values.json
jq '.AppSettings' values.json > appsettings.json
jq '.["Storage.CreateBucket.OnTenantCreation.Enabled"] = "true"' appsettings.json > temp.json && mv -f temp.json appsettings.json
./bin/uipathctl config orchestrator update-config --app-settings appsettings.json
To install jq, use one of the following options:
Option 1: Run the following command:
yum install -y epel-release yum install -y jqyum install -y epel-release yum install -y jq -
Option 2: Run the following commands:
shell curl https://download-ib01.fedoraproject.org/pub/epel/7/x86_64/Packages/j/jq-1.6-2.el7.x86_64.rpm --output /tmp/jq-1.6-2.el7.x86_64.rpm yum localinstall /tmp/jq-1.6-2.el7.x86_64.rpmshell curl https://download-ib01.fedoraproject.org/pub/epel/7/x86_64/Packages/j/jq-1.6-2.el7.x86_64.rpm --output /tmp/jq-1.6-2.el7.x86_64.rpm yum localinstall /tmp/jq-1.6-2.el7.x86_64.rpm
Failing to enable the Orchestrator setting that ensures buckets are automatically created with the correct CORS policy causes issues with downloading from storage buckets, which you must address by making manual updates to the CORS policy.
To confirm that the setting has been enabled, run the following command:
If the setting has been enabled, the command should return the following response:
"AppSettings": {
"Storage.CreateBucket.OnTenantCreation.Enabled": "true"
"AppSettings": {
The UiPath.OrganizationMigrationApp tool helps you perform operations such as move the Identity data of all tenants from standalone to Automation Suite and merge organizations.
To download UiPath.OrganizationMigrationApp, see Downloading the installation packages.
To see which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
Tool for managing Microsoft SQL Server
You must download and install SQL Server Management Studio (SSMS) or a similar tool for managing Microsoft SQL Server. This tool helps you restore the Orchestrator database to the Automation Suite SQL Server instance or a different SQL Server instance.
- Download and install SQL Server Management Studio.
- Log into the standalone SQL Server using the standalone SQL connection string.
- Open port
1433for the source and target database.
Special character escape rules for connection string passwords
In most instances, connection passwords are encapsulated within a single quotation mark ('). However, when the password includes special characters such as ``` or $, a different approach is required.
In these cases, the password must be formatted as \", replacing
| Original format in ADUC | Escaped format in PowerShell string |
cn=James $ Smith | "cn=James $ Smith"` |
cn=Sally Wilson + Jones | "cn=Sally Wilson \+ Jones" |
cn=William O'Brian | "cn=William O'Brian" |
cn=William OBrian` | "cn=William O``Brian" |
cn=Richard #West | "cn=Richard #West" |
cn=Roy Johnson$ | "cn=Roy Johnson$" |
Example
Assume that the original password is 7'8:<=XMe$y[@vC?_4ZeY8c-~y'W!1dU4gnczuf'/p>j<I. Adhering to the special character escape rules, it becomes: Password=\"7'8:<=XMe$y[@vC?_4ZeY8c-~y'W!1dU4```gnczuf'/p>```j<I\"`.
The full command, with the password configured in destination connection string, looks as follows:
./UiPath.OrganizationMigrationApp.exe migrate -a -m -s "Server=tcp:abc.com,1433;Initial Catalog=UiPath_20230531;Persist Security Info=False;User ID=username;Password=asiodhyf;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;" -d "Server=tcp:cde.net,1433;Initial Catalog=AutomationSuite_Platform;Persist Security Info=False;User Id=testadmin@sfdev3980732-sql.database.windows.net;Password=\`"7'8:<=XMe`$y[@vC?_4ZeY8c-~y'W!1dU4```gnczuf'/p>```j<I\`""
