- Overview
- Requirements
- Q&A: Deployment templates
- Install-uipath.sh Parameters
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Unable to launch Automation Hub and Apps with proxy setup
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- MongoDB Pod Fails to Upgrade From 4.4.4-ent to 5.0.7-ent
- Pods stuck in Init:0/X
- Exploring Logs
Configuring the DNS
The Automation Suite cluster is exposing multiple URLs to access the cluster management tools and the suite core functionality, all based on a common FQDN.
You must configure the DNS for the common FQDN and the subdomains specific to each tool as shown in the following table.
| Application | Domain | Example URL |
| Automation Suite | fqdn | automationsuite.mycompany.com |
| Application Lifecycle Management (ALM) | alm.{{fqdn}} | alm.automationsuite.mycompany.com |
| Monitoring / Observability | monitoring.{{fqdn}} | monitoring.automationsuite.mycompany.com |
| Object Store | objectstore.{{fqdn}} | objectstore.automationsuite.mycompany.com |
| Docker Registry | registry.{{fqdn}} | registry.automationsuite.mycompany.com |
| Insights | insights.{{fqdn}} | insights.automationsuite.mycompany.com |
Configuring DNS using public domain registrar
Add a A Record in Advanced DNS or Management section of your domain as shown in the following table:
| Type | Host | Value |
See the following example for the configuration:
If the * wildcard is too generic, add a separate record or rule for the following subdomains: alm, monitoring, objectstore, registry, and insights.
