- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
This page helps you weigh the benefits of each deployment method for Automation Suite.
This table compares the feature availability across the following deployment methods:
- the AWS, Azure, and GCP cloud templates, which provision the infrastructure and install Automation Suite in a short amount of time. Templates are the recommended option.
the manual installation provisioning method, which requires more technical expertise and is considerably more time-consuming.
Feature
AWS template
Azure template
GCP template
Manual installation provisioning
Deploy to existing Virtual Network
Single-node evaluation vs. multi-node HA-ready production
Note:Can set number of instances
Air-gapped
Basic vs. complete product selection
Note: Allows each service to be enabledNote: Allows each service to be enabledNote: Allows each service to be enabledCustom domain (cloud-provided DNS service or not)
Custom certificates
Deploy to existing SQL Server
Hardware requirements validation
Template uses cloud-native availability zones
N/A
Auto scaling for agent nodes
N/A
Proxy configuration
Optional bastion host
N/A
Instance refresh
N/A
