- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
This table compares the feature availability across the following deployment methods:
- the AWS, Azure, and GCP cloud templates, which provision the infrastructure and install Automation Suite in a short amount of time. Templates are the recommended option.
the manual installation provisioning method, which requires more technical expertise and is considerably more time-consuming.
Feature
AWS template
Azure template
GCP template
Manual installation provisioning
Deploy to existing Virtual Network
Single-node evaluation vs. multi-node HA-ready production
:fa-info-circle: Can set number of instances
Air-gapped
Basic vs. complete product selection
Note: Allows each service to be enabledNote: Allows each service to be enabledNote: Allows each service to be enabledCustom domain (cloud-provided DNS service or not)
Custom certificates
Deploy to existing SQL Server
Hardware requirements validation
Template uses cloud-native availability zones
N/A
Auto scaling for agent nodes
N/A
Proxy configuration
Optional bastion host
N/A
Instance refresh
N/A
