- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Post-migration steps are mandatory and include:
Updating Identity Application Secrets With Previously Saved Identity Configuration Data
Take the following steps:
- Run
kubectl edit secret platform-service-secrets -n uipathand updateidentity.sqlConnectionString,identity.hostAdminUsername, andidentity.hostAdminPasswordusing base64 encoded values. - Use the instructions provided in Updating the Identity token signing certificate.
- If using SAML, run
kubectl edit secret identity-saml-certificates -n uipathand updatecurrent.saml2.pfxandfuture.saml2.pfxvia the decrypted private keys, andcurrentCertPasswordandfutureCertPasswordvia base64 encoded values. - If using Kerberos, run
kubectl edit secret krb5-keytab -n uipathand update thekrb5.keytabvalue.
Remove old Identity cache keys
- Run
kubectl --kubeconfig <directory of SF cluster yaml file> get secrets/redb-redis-cluster-db -n uipath --template '{{ .data.password }}'to get Redis password. Decode the Base64 value. - Run
kubectl --kubeconfig <directory of SF cluster yaml file> get secrets/redb-redis-cluster-db -n uipath --template '{{ .data.port }}'to get Redis port. Decode the Base64 value. - Run
kubectl --kubeconfig <directory of SF cluster yaml file> exec -i -t -n redis-system redis-cluster-0 -c redis-enterprise-node "--" sh -c "clear; (bash || ash || sh)"to get into Redis node. - Use port and password got from previous commands to run
redis-cli -p <Port number> -a <Password> --scan --pattern is:* | xargs redis-cli -p <Port number> -a <Password> delto delete the old keys. - Run exit to get out.
Running Identity Server DataMigrator CLI
C:\Program Files (x86)\UiPath\Orchestrator\Identity\Tools\DataMigrator.Cli-
.\UiPath.DataMigrator.Cli.exe kube-migrate -d <identity.sqlConnectionString for the k8s env>Restart identity-service-api after running the migrator command.
For Linux
Prerequisites
The MSIToAutomationSuiteTenantMigrator tool requires .NET 6.0 at a minimum. If .NET 6.0 or later is not present, download and install .NET Runtime for Linux before using the MSIToAutomationSuiteTenantMigrator tool.
sudo yum install dotnet-sdk-6.0 -yDownloading the tool
The MSIToAutomationSuiteTenantMigrator tool is available for download here.
Running the tool
\ before special characters.
To link tenants from a standalone installation to Automation Suite, run:
./MSIToAutomationSuiteTenantMigrator -s '<Orchestrator DB connection string (the one cloned from the standalone installation server)>' -p '<Platform DB connection string (Automation Suite)>' -t '<List of tenant names separated by comma, e.g. orchTenant1,orchTenant2>'./MSIToAutomationSuiteTenantMigrator -s '<Orchestrator DB connection string (the one cloned from the standalone installation server)>' -p '<Platform DB connection string (Automation Suite)>' -t '<List of tenant names separated by comma, e.g. orchTenant1,orchTenant2>'For Windows
Prerequisites
The MSIToAutomationSuiteTenantMigrator tool requires .NET 6.0 at a minimum. If .NET 6.0 and beyond is not present, download and install .NET Runtime 6.0.3 for Windows before using the MSIToAutomationSuiteTenantMigrator tool.
Running the tool
$ with `$.
MSIToAutomationSuiteTenantMigrator.exe -s "<Orchestrator DB connection string (the one cloned from the standalone installation server)>" -p "<Platform DB connection string (Automation Suite)>" -t "<List of tenant names separated by comma, e.g. orchTenant1,orchTenant2>"MSIToAutomationSuiteTenantMigrator.exe -s "<Orchestrator DB connection string (the one cloned from the standalone installation server)>" -p "<Platform DB connection string (Automation Suite)>" -t "<List of tenant names separated by comma, e.g. orchTenant1,orchTenant2>"Updating SMTP Configuration Information
Configure SMTP for the host and (optionally) for any organizations where you want to use different SMTP settings than the host.
To configure AD integration, refer to Configuring SSO: Active Directory.
If AD integration and authentication were enabled in the standalone deployment, take the following steps in the Automation Suite cluster:
- Make sure the domain controllers are discoverable by the Automation Suite cluster. If not, use the Kube DNS configuration;
- Configure integrated Windows authentication and Kerberos authentication using keytab file;
- Configure LDAP integration via the Portal under the host admin;
- Configure Windows authentication via the Portal under the host admin;
Configure LDAPS for secure connection to LDAP.
Note: The account used for the LDAP integration configuration should only have read access to all trusted domains in the current and trusted forests.
Update the Orchestrator configuration. Make sure to review the following:
- Custom configuration from
UiPath.Orchestrator.dll.config - Any
web.configsettings. - Storage (packages, execution media, and buckets data) - mostly applicable to
Storage.Type=FileSystem - Custom NLog targets.
- Custom credential stores.
- Encryption key per tenant configuration.
You can simplify many of the following steps by using the provided Orchestrator Configurator Tool.
orchestrator_configurator.sh bash tool can update the Orchestrator custom config map and upload files to the Orchestrator well-known blob storage locations.
Use the -y parameter to skip confirmation of the proposed actions.
Configuring web.config
orchestrator-customconfig config map using a tool such as Lens or kubectl.
values.json file. The Orchestrator deployment should restart automatically after this configuration change.
"Kestrel": {
"Limits": {
"MaxRequestBodySize": 314572800
"Kestrel": {
"Limits": {
}Configuring appSettings
appsettings.json file edited in the pre-migration steps now contains all the customization needed in the appSettings section. You need to place this .json file in the orchestrator-customconfig config map, in the values.json file, under the appSettings key.
"ExampleSetting.Enabled": true,
"ExampleSetting.Type": "BasicExample",
"ExampleSetting.Count": 3
}appSettings with the keys already present in the config map. You can upload the app settings using the -c|--app-settings parameter:
./orchestrator_configurator.sh -c appsettings.json./orchestrator_configurator.sh -c appsettings.jsonappSettings overrides, and run the script once at the end.
Configuring Storage
FileSystem storage to Orchestrator's storage provider, use the Orchestrator Configurator Tool to transfer the storage content.
-s|--storage-folder parameter in the Orchestrator Configurator Tool, where path is the parent folder. Replace the path with the folder's location where your files are stored. To determine the path, check
the Storage.Path parameter in UiPath.Orchestrator.dll.config.
To ensure it's the correct folder, it should contain this hierarchy:
One folder named Orchestrator-Host\Libraries.
One folder for each tenant, named Orchestrator-[tenantKey].
./orchestrator_configurator.sh -s path./orchestrator_configurator.sh -s pathThe command uploads the contents of the path folder to the configured storage provider.
The Orchestrator Configurator tool only supports CEPH, S3 (or compatible), or Azure Blob Storage. For any other storage, copy the content to the new location manually.
To use network FileStore, edit the Orchestrator ArgoCD app parameters, and set the following:
storage.type = smbstorage.smb.domainstorage.smb.passwordstorage.smb.sourcestorage.smb.usernamestorage.smb.size
To configure other storage options, edit the Orchestrator ArgoCD app parameters and set the following:
storage.typeto the desired provider (Azure, AWS, Minio)storage.connectionString
Overview of the Orchestrator app storage settings:
Azure/Amazon S3 Storage Buckets
Orchestrator web browser access to Amazon and Azure storage buckets can be restricted due to the same-origin policy on the provider side. Successfully accessing the content of such a bucket requires you to configure the respective provider to allow cross-origin requests from Orchestrator.
See instructions on how to configure each provider to allow cross-origin requests from Orchestrator.
Configuring NLog
Ceph, in the uipath bucket. The Orchestrator pod will then be able to load them at startup. You also need to place the configuration in orchestrator-customconfig in the nlog.json file.
-n|--nlog-extensions-folder and -l|--nlog-config-file parameters.
./orchestrator_configurator.sh -n nlogextensions -l nlog.custom.json./orchestrator_configurator.sh -n nlogextensions -l nlog.custom.json/var/orchestrator/plugins/nlog. The configurator automatically updates the assemblyFile paths, prepending the plugins path to them.
Configuring credential stores
appsettings.json, so there are no more required configuration updates.
values.json file of orchestrator-customconfig under the appSettings section.
/var/orchestrator/plugins/securestore/ path.
-p|--securestore-plugins-folder parameter:
./orchestrator_configurator.sh -p securestoreplugins./orchestrator_configurator.sh -p securestorepluginsConfiguring encryption key
orchestrator-generated-secrets by overwriting the value of APPSETTINGS__EncryptionKey.
Configuring encryption key per tenant
To migrate the encryption key per tenant, take the following steps:
cluster_config.json file. This ensures all changes made via ArgoCD are properly saved in the Automation Suite configuration file.
cluster_config.json, run the following command:
./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o ./cluster_config.json./configureUiPathAS.sh config get -i /path/to/old/cluster_config.json -o ./cluster_config.jsoncreate_db to false. Not doing so would prevent the installer from overriding SQL connection strings and retaining the latest state of the cluster.
cluster_config.json at this stage. The operation requires running the installer, which reverts the changes made to the SQL connection strings.
For details on the alternative options to configure Kerberos authentication, see Configuring Automation Suite as a Kerberos client.
- Step 1: Updating secrets and Identity Server configuration
- Updating Identity Application Secrets With Previously Saved Identity Configuration Data
- Remove old Identity cache keys
- Running Identity Server DataMigrator CLI
- Step 2: Linking tenants from a standalone installation to Automation Suite
- For Linux
- For Windows
- Updating SMTP Configuration Information
- Step 3: Updating AD Integration and Authentication
- Step 4: Updating the Orchestrator Configuration
- Configuring web.config
- Configuring appSettings
- Configuring Storage
- Azure/Amazon S3 Storage Buckets
- Configuring NLog
- Configuring encryption key
- Step 5: Recreating cluster_config.json
- Step 6: Reconnecting Robots
