Sample Azure Infrastructure Setup
The following table lists the steps you need to take to configure the infrastructure in Azure for both single-node evaluation and multi-node HA-ready production profiles.
Step
Instructions
Single-node evaluation profile
Multi-node HA-ready production profile
Required during installation
Step 1: Configure a VM node
Configure one node
Configure a minimum of 3 nodes.
  • Follow additional instructions specific to multi-node.
  • Username and password used when creating the VM.
  • FQDN of the first VM.
  • For the single-node evaluation profile, provide this FQDN as the Cluster FQDN.
N/A
Required
  • FQDN of the load balancer.
  • For multi-node, provide this FQDN as the Cluster FQDN.
Required
Required
  • SQL Server FQDN and SQL Server credentials.
For production deployments:
For test or evaluation deployments:
Required
Required
Step 5: Install Automation Suite
At this point, configuration is complete, and you can install Automation Suite.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
