- Overview
- Requirements
- Cluster administration
- Managing products
- Backing up and Restoring the Cluster
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
You can enable and disable products in Automation Suite at any point post-installation.
cluster_config.json file stored in the
/opt/UiPathAutomationSuite folder, and rerun the service
installer step.
Enabling or disabling Action Center
cluster_config.json file:
"actioncenter": {
"enabled": "true" //Set to "false" to disable the Action Center
}"actioncenter": {
}Enabling or Disabling Apps
"apps": {
"enabled": "true" //Set to "false" to disable the Apps
}"apps": {
}Enabling or Disabling AI Center
enable flag and an SQL database.
sql_connection_string_template_jdbc in cluster_config.json, then the default AI Center database name is AutomationSuite_AICenter.
sql_connection_str inside the AI Center field. This overrides the default database and connection string template set in sql_connection_string_template_jdbc.
cluster_config.json:
"aicenter": {
"enabled": "true", //Set to "false" to disable the AICenter
"sql_connection_str": "" //Optional and only require to override the default database name
}"aicenter": {
}Enabling or disabling Automation Hub
automation_hub section of the cluster_config.json file, set the enabled flag
to true:
"automation_hub": {
"enabled": "true" //Set to "false" to disable Automation Hub
}"automation_hub": {
}enabled flag to false in the
automation_hub section of the cluster_config.json file.
Enabling or disabling Automation Ops
sql_connection_string_template in cluster_config.json, then the default database name for
Automation Ops is AutomationSuite_Platform.
sql_connection_str inside the Automation Ops field. This overrides the default database and connection string template set in sql_connection_string_template.
"automation_ops": {
"enabled": "true", //Set to "false" to disable the Automation Ops
}"automation_ops": {
}Enabling or Disabling Document Understanding
sql_connection_string_template_odbc in cluster_config.json, then the default database name is AutomationSuite_DU_Datamanager.
sql_connection_str inside the Document Understanding field. This overrides the default database and connection string template set in sql_connection_string_template_odbc.
If you perform an offline installation, you need to download the offline bundle for Document Understanding as well. Before enabling Document Understanding, please refer to Install and Use Document Understanding.
"documentunderstanding": {
"enabled": "true" //Set to "false" to disable the Document Understanding
}"documentunderstanding": {
}Enabling or Disabling Insights
sql_connection_string_template in cluster_config.json, then the default database name is AutomationSuite_Insights.
sql_connection_str inside the Insights field. This overrides the default database and connection string template set in sql_connection_string_template.
Insights has an optional SMTP configuration to enable receiving email notifications. Refer to Advanced installation experience for more details.
"insights": {
"enabled": "true" //Set to "false" to disable the Insights,
}"insights": {
}Enabling or Disabling Task Mining
enable flag and an SQL Database.
sql_connection_string_template in cluster_config.json, then the default database name is AutomationSuite_Task_Mining.
To change the name to something other than the default, you can update the sql_connection_str inside the Task Mining field to override the default database and connection string template set in sql_connection_string_template
Task Mining requires a few additional steps, including the provisioning of a dedicated agent node for AI-specific workloads. Before enabling Task Mining, please refer Task Mining installation section Adding a dedicated agent node for Task Mining
"task_mining": {
"enabled": "true" //Set to "false" to disable the Task Mining,
}"task_mining": {
}Enabling or Disabling Test Manager
sql_connection_string_template in cluster_config.json, then the default database name is AutomationSuite_Test_Manager.
sql_connection_str inside the Test Manager field. This overrides the default database and connection string template set in sql_connection_string_template.
"test_manager": {
"enabled": "true" //Set to "false" to disable the Test Manager,
}"test_manager": {
}cluster_config.json, run the following command on the installer to update the service configuration.
For online installations:
./install-uipath.sh -i cluster_config.json -o output.json -s --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -s --accept-license-agreement -
For offline installations:
./install-uipath.sh -i cluster_config.json -o output.json -s --install-type offline --accept-license-agreement./install-uipath.sh -i cluster_config.json -o output.json -s --install-type offline --accept-license-agreement
- Step 1: Changing the product selection in the configuration file
- Enabling or disabling Action Center
- Enabling or Disabling Apps
- Enabling or Disabling AI Center
- Enabling or disabling Automation Hub
- Enabling or disabling Automation Ops
- Enabling or Disabling Document Understanding
- Enabling or Disabling Insights
- Enabling or Disabling Task Mining
- Enabling or Disabling Test Manager
- Step 2: Running the installer script to update the new product configuration
