2022.4
Managing products
You can enable and disable products in Automation Suite at any point post-installation.
To do that, you must access and update the cluster_config.json file stored in the /opt/UiPathAutomationSuite folder, and rerun the service installer step.
Note: You need to perform these steps only from Server Nodes.
Step 1: Changing the product selection in the configuration file
  1. Change the product selection in the configuration file.
    To do that, navigate to the UiPathAutomationSuite folder and edit cluster_config.json.
    cd /opt/UiPathAutomationSuite
    nano cluster_config.json #optionally use any favourite editor of your choice.cd /opt/UiPathAutomationSuite
  2. In the services list, set the enable flags to true or false for the specific services you want to enable or disable. See the following examples for individual products.
    Note: You can manage Action Center and Apps simply by updating the enable flag. Other products might require an additional step to configure the installation. See the following instructions for details.
Enabling or disabling Action Center
See the following configuration details for enabling or disabling Action Center in the cluster_config.json file:
"actioncenter": {
  "enabled": "true" //Set to "false" to disable the Action Center
}"actioncenter": {
Enabling or Disabling Apps
See the following configuration details for enabling or disabling Apps in the cluster_config.json file:
"apps": {
  "enabled": "true" //Set to "false" to disable the Apps
}"apps": {
Enabling or Disabling AI Center
AI Center requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template_jdbc in cluster_config.json, then the default AI Center database name is AutomationSuite_AICenter.
To change the default database name, you need to update the sql_connection_str inside the AI Center field. This overrides the default database and connection string template set in sql_connection_string_template_jdbc.
See the following configuration details for enabling or disabling AI Center in cluster_config.json:
"aicenter": {
  "enabled": "true", //Set to "false" to disable the AICenter
  "sql_connection_str": "" //Optional and only require to override the default database name
}"aicenter": {
Enabling or disabling Automation Hub
To enable Automation Hub, in the automation_hub section of the cluster_config.json file, set the enabled flag to true:
"automation_hub": {
  "enabled": "true" //Set to "false" to disable Automation Hub
}"automation_hub": {
To disable Automation Hub, set the enabled flag to false in the automation_hub section of the cluster_config.json file.
Enabling or disabling Automation Ops
Automation Ops requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template in cluster_config.json, then the default database name for Automation Ops is AutomationSuite_Platform.
To change the default database name, you need to update the sql_connection_str inside the Automation Ops field. This overrides the default database and connection string template set in sql_connection_string_template.
Note: Automation Ops shares a database with the core platform, including Orchestrator. If you change the database here, you update the database for the core platform as well.
See the following configuration details for enabling or disabling Automation Ops in cluster_config.json:
"automation_ops": {
  "enabled": "true", //Set to "false" to disable the Automation Ops
}"automation_ops": {
Enabling or disabling Data Service
Data Service requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template in cluster_config.json, then the default database name is AutomationSuite_DataService.
To change the default database name, you need to update the sql_connection_str inside the Data Service field. This overrides the default database and connection string template set in sql_connection_string_template.
See the following configuration details for enabling or disabling Data Service in cluster_config.json:
"dataservice": {
  "enabled": "true", //Set to "false" to disable the Data Service,
}"dataservice": {
Enabling or disabling Document Understanding
Document Understanding requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template_odbc in cluster_config.json, then the default database name is AutomationSuite_DU_Datamanager.
To change the default database name, you need to update the sql_connection_str inside the Document Understanding field. This overrides the default database and connection string template set in sql_connection_string_template_odbc.
If you perform an offline installation, you need to download the offline bundle for Document Understanding as well. Before enabling Document Understanding, please refer to Install and Use Document Understanding.
See the following configuration details for enabling or disabling Document Understanding in cluster_config.json:
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "***" // dotnet connection string,
"datamanager": {
 "sql_connection_str": "***" // odbc connection string
 "pyodbc_sql_connection_str": "***" // python sql connection string
}"documentunderstanding": {
"enabled": true,
"datamanager": {
Enabling or Disabling Insights
Insights requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template in cluster_config.json, then the default database name is AutomationSuite_Insights.
To change the default database name, you need to update the sql_connection_str inside the Insights field. This overrides the default database and connection string template set in sql_connection_string_template.
Insights has an optional SMTP configuration to enable receiving email notifications. Refer to Advanced installation experience for more details.
See the following configuration details for enabling or disabling Insights in cluster_config.json:
"insights": {
  "enabled": "true", //Set to "false" to disable the Insights,
}"insights": {
Enabling or disabling Task Mining
Task Mining requires update the enable flag and an SQL Database.
If you previously set a value for sql_connection_string_template in cluster_config.json, then the default database name is AutomationSuite_Task_Mining.
To change the name to something other than the default, you can update the sql_connection_str inside the Task Mining field to override the default database and connection string template set in sql_connection_string_template
Task Mining requires a few additional steps, including the provisioning of a dedicated agent node for AI-specific workloads.
Before enabling Task Mining, please refer Task Mining installation section Adding a dedicated agent node for Task Mining.
See the following configuration details for enabling or disabling Task Mining in cluster_config.json:
"task_mining": {
  "enabled": "true", //Set to "false" to disable the Task Mining,
}"task_mining": {
Un-tainting for workloads
If desired, the Task Mining node can be repurposed as an agent node. To accomplish this, run the following commands:
  1. Check an actual taint using kubectl describe node task-mining_nodename command.
  2. Run the command kubectl taint nodes task-mining_nodename task.mining/cpu=present:NoSchedule-.
  3. Check taint has disappeared using kubectl describe node task-mining_nodename command.
Enabling or Disabling Test Manager
Test Manager requires updating the enable flag and an SQL database.
If you previously set a value for sql_connection_string_template in cluster_config.json, then the default database name is AutomationSuite_Test_Manager.
To change the default database name, you need to update the sql_connection_str inside the Test Manager field. This overrides the default database and connection string template set in sql_connection_string_template.
See the following configuration details for enabling or disabling Test Manager in cluster_config.json:
"test_manager": {
  "enabled": "true", //Set to "false" to disable the Test Manager,
}"test_manager": {
Important: Once you update the configuration file, then proceed to Step 2.
Step 2: Running the installer script to update the new product configuration
Once you update the cluster_config.json, run the following command on the installer to update the service configuration.
  • For online installations:
    ./install-uipath.sh -i cluster_config.json -o output.json -s --accept-license-agreement
  • For offline installations:
    ./install-uipath.sh -i cluster_config.json -o output.json -s --install-type offline --accept-license-agreement
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
