Step 7: Configuring the DNS
DNS configuration requirements for the cluster FQDN and subdomains used by Automation Suite tools and services.
The Automation Suite cluster is exposing multiple URLs to access the cluster management tools and the suite core functionality, all based on a common FQDN.
You must configure the DNS for the common FQDN and the subdomains specific to each tool as shown in the following table.
Note:
We support only lowercase FQDNs. Do not use uppercase characters in your FQDN.
ApplicationDomainExample URL
Automation Suitefqdnautomationsuite.mycompany.com
Application Lifecycle Management (ALM)alm.{{fqdn}}alm.automationsuite.mycompany.com
Monitoring / Observabilitymonitoring.{{fqdn}}monitoring.automationsuite.mycompany.com
Object Storeobjectstore.{{fqdn}}objectstore.automationsuite.mycompany.com
Docker Registryregistry.{{fqdn}}registry.automationsuite.mycompany.com
Insightsinsights.{{fqdn}}insights.automationsuite.mycompany.com
Appsapps.{{fqdn}}apps.automationsuite.mycompany.com
Important:
The monitoring DNS entries are optional and depend on whether you use the internal monitoring solution. However, if you enable the built-in monitoring solution at any point, you must ensure the corresponding DNS entries are added first to allow proper access and functionality.
Configuring DNS using public domain registrar
Add a A Record in Advanced DNS or Management section of your domain as shown in the following table:
Type
Host
Value
A Record (or CName ) automationsuite (or a subdomain to access Automation Suite)
  • For A Record : IP Address of Load Balancer
  • For CName : DNS name associated with Load Balancer
A Record (or CName ) *.automationsuite (or a subdomain to access Automation Suite)
See the following example for the configuration:
Note:
If the * wildcard is too generic, add a separate record or rule for the following subdomains: alm, monitoring, objectstore, registry, insights and apps.
Configuring the DNS in a multi-site deployment
Automation Suite multi-site deployments require that you configure the DNS for the common FQDN and the subdomains specific to each tool as shown in the following table:
Application
Domain
Example
Value
Primary Cluster FQDN
fqdn-primary
automationsuite-primary.mycompany.com
  • For A Record : the IP address of the primary cluster’s load balancer
  • For CName : the DNS name associated with the primary cluster’s load balancer
Secondary Cluster FQDN
fqdn-secondary
automationsuite-secondary.mycompany.com
  • For A Record : the IP address of the secondary cluster’s load balancer
  • For CName : the DNS name associated with the secondary cluster’s load balancer
alm.{{fqdn-primary}}
alm.automationsuite-primary.mycompany.com
alm.{{fqdn-secondary}}
alm.automationsuite-secondary.mycompany.com
Monitoring
monitoring.{{fqdn-primary}}
monitoring.automationsuite-primary.mycompany.com
monitoring.{{fqdn-secondary}}
monitoring.automationsuite-secondary.mycompany.com
Registry (For offline only)
registry.{{fqdn-primary}}
registry.automationsuite-primary.mycompany.com
registry.{{fqdn-secondary}}
registry.automationsuite-secondary.mycompany.com
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
