Configuring the DNS
The Automation Suite cluster is exposing multiple URLs to access the cluster management tools and the suite core functionality, all based on a common FQDN.
You must configure the DNS for the common FQDN and the subdomains specific to each tool as shown in the following table.
Application
Domain
Example URL
Automation Suite
fqdn
automationsuite.mycompany.com
Application Lifecycle Management (ALM)
alm.{{fqdn}}
alm.automationsuite.mycompany.com
Monitoring / Observability
monitoring.{{fqdn}}
monitoring.automationsuite.mycompany.com
Object Store
objectstore.{{fqdn}}
objectstore.automationsuite.mycompany.com
Docker Registry
registry.{{fqdn}}
registry.automationsuite.mycompany.com
Insights
insights.{{fqdn}}
insights.automationsuite.mycompany.com
Configuring DNS using public domain registrar
Add a A Record in Advanced DNS or Management section of your domain as shown in the following table:
Type
Host
Value
A Record (or CName)
automationsuite (or a subdomain to access Automation Suite)
  • For A Record: IP Address of Load Balancer
  • For CName: DNS name associated with Load Balancer
A Record (or CName)
*.automationsuite (or a subdomain to access Automation Suite)
See the following example for the configuration:
Note: If the * wildcard is too generic, add a separate record or rule for the following subdomains: alm, monitoring, objectstore, registry, and insights.
Configuring the DNS in a multi-site deployment
Automation Suite multi-site deployments require that you configure the DNS for the common FQDN and the subdomains specific to each tool as shown in the following table:
Application
Domain
Example
Value
Primary Cluster FQDN
fqdn-primary
automationsuite-primary.mycompany.com
  • For A Record: the IP address of the primary cluster’s load balancer
  • For CName: the DNS name associated with the primary cluster’s load balancer
Secondary Cluster FQDN
fqdn-secondary
automationsuite-secondary.mycompany.com
  • For A Record: the IP address of the secondary cluster’s load balancer
  • For CName: the DNS name associated with the secondary cluster’s load balancer
alm.{{fqdn-primary}}
alm.automationsuite-primary.mycompany.com
alm.{{fqdn-secondary}}
alm.automationsuite-secondary.mycompany.com
Monitoring
monitoring.{{fqdn-primary}}
monitoring.automationsuite-primary.mycompany.com
monitoring.{{fqdn-secondary}}
monitoring.automationsuite-secondary.mycompany.com
Registry (For offline only)
registry.{{fqdn-primary}}
registry.automationsuite-primary.mycompany.com
registry.{{fqdn-secondary}}
registry.automationsuite-secondary.mycompany.com
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
