- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
Apply a patch to an existing Automation Suite version to address bugs or security vulnerabilities.
An Automation Suite patch is an update to an existing version, which addresses bugs or security vulnerabilities. For instance, patch 2023.10.3+patch1 addresses issues impacting version 2023.10.3.
Instead of applying the patch, we recommend upgrading to the Cumulative Update (CU) that contains the same fix. All fixes provided in patches will also be available in the CU mentioned in the release notes for the patch.
To apply a patch to an existing Automation Suite version, take the following steps:
Offline only. Update the registry with the latest images.
- Download the following patch artifacts from Patch artifact download links. Choose the set of artifacts applicable to your patch and registry configuration type.
- To mirror the OCI-compliant registry with the UiPath® registry, download the following artifacts:
as-images.txtas-helm-charts.txtmirror-registry.sh
- To hydrate the OCI-compliant registry with the offline bundle, download the following artifacts:
hydrate-registry.shas.tar.gz
- To use the in-cluster registry, download the following artifacts:
as-fs.tar.gzdocker-images.jsonversions.json
- Configure the OCI-compliant registry.
Important:
Do not download the artifacts from the links referenced in the instructions on configuring the OCI-compliant registry. Instead, use the download links provided on the Patch artifact download links page.
Download
versions.json. For instructions, refer to Patch artifact download links. -
Apply the patch by running the following command:
uipathctl cluster patch <path_to_cluster_config.json> --versions <path_to_versions.json> --skip-helm --skip-oss-prereq --only <PRODUCTS(comma separated)>uipathctl cluster patch <path_to_cluster_config.json> --versions <path_to_versions.json> --skip-helm --skip-oss-prereq --only <PRODUCTS(comma separated)>The following configuration sample shows how to apply a patch to Orchestrator and Action Center:
uipathctl cluster patch <path_to_cluster_config.json> --versions <path_to_versions.json> --skip-helm --skip-oss-prereq --only orchestrator,actioncenteruipathctl cluster patch <path_to_cluster_config.json> --versions <path_to_versions.json> --skip-helm --skip-oss-prereq --only orchestrator,actioncenter -
Check if the patch operation was successful by taking the following steps:
- Run the following command to list the versions of all services:
kubectl -n argocd get application -o widekubectl -n argocd get application -o wide - Verify that the versions of the patched services are updated.
