Applying a patch
Apply a patch to an existing Automation Suite version to address bugs or security vulnerabilities.
An Automation Suite patch is an update to an existing version, which addresses bugs or security vulnerabilities. For instance, patch 2.2510.0+patch1 addresses issues impacting version 2.2510.0.
Important:
Instead of applying the patch, we recommend upgrading to the Cumulative Update (CU) that contains the same fix. All fixes provided in patches will also be available in the CU mentioned in the release notes for the patch.
To apply a patch to an existing Automation Suite version, take the following steps:
  1. Offline only. Update the registry with the latest images.
    1. Download the following patch artifacts from Patch artifact download links. Choose the set of artifacts applicable to your patch and registry configuration type.
      • To mirror the OCI-compliant registry with the UiPath® registry, download the following artifacts:
        • as-images.txt
        • as-helm-charts.txt
        • mirror-registry.sh
      • To hydrate the OCI-compliant registry with the offline bundle, download the following artifacts:
        • hydrate-registry.sh
        • as.tar.gz
      • To use the in-cluster registry, download the following artifacts:
        • as-fs.tar.gz
        • docker-images.json
        • versions.json
    2. Important:
      Do not download the artifacts from the links referenced in the instructions on configuring the OCI-compliant registry. Instead, use the download links provided on the Patch artifact download links page.
  2. Download the corresponding uipathctl patch version from Patch artifact download links. Replace the current uipathctl version located in the ./bin installer directory with the patched uipathctl version.
    Note:
    For details on how to set up uipathctl CLI, refer to Running uipathctl.
  3. Download versions.json. For instructions, refer to Patch artifact download links.
  4. Apply the patch by running the following commands:
    Note:
    <current versions.json> refers to the versions.json file for the current installation. You can find the file in the following location: <installer_directory>/versions/helm-charts.json.
    You must download the patch versions.json into a directory, and pass the directory path to the --patch-dir-path parameter.
    To apply the patches, store all the relevant versions.json files in a single directory.
    cd /opt/UiPathAutomationSuite/latest/installer
    ./bin/uipathctl cluster patch cluster_config.json --versions <current versions.json> --skip-oss-prereq --only <PRODUCTS(comma separated)> --patch-dir-path <path to patch versions.json files directory>
    The following configuration sample shows how to apply a patch to Orchestrator and Action Center:
    ./bin/uipathctl cluster patch cluster_config.json --versions <current versions.json> --skip-oss-prereq --only orchestrator,actioncenter --patch-dir-path <path to patch versions.json files directory>
  5. Check if the patch operation was successful by taking the following steps:
    1. Run the following command to list the versions of all services:
       kubectl -n argocd get application -o wide || helm list -A
    2. Verify that the versions of the patched services are updated.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
