2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
While installing or upgrading Automation Suite, if the MongoDB pods cannot mount to the PVC pods, the following error message is displayed:
UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY
If you encounter the error above, follow the recovery steps below:
SSH to the system by running the following command:
ssh <user>@<node-ip>ssh <user>@<node-ip> -
Check the events of the PVC and verify that the issue is related to the PVC mount failure due to file error. To do this, run the following command:
export KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin:/usr/local/bin kubectl get events -n mongodb kubectl get events -n longhorn-systemexport KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin:/usr/local/bin kubectl get events -n mongodb kubectl get events -n longhorn-system -
Check the PVC volume mentioned in the event and run the
fsckcommand.fsck -a <pvc-volume-name> Eg - fsck -a /dev/longhorn/pvc-5abe3c8f-7422-44da-9132-92be5641150afsck -a <pvc-volume-name> Eg - fsck -a /dev/longhorn/pvc-5abe3c8f-7422-44da-9132-92be5641150a -
Delete the failing MongoDB pod to properly mount it to the PVC.
kubectl delete pod <pod-name> -n mongodbkubectl delete pod <pod-name> -n mongodb
