- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Step 1: Saving the connection strings
- Step 2: Creating your organizations in Automation Suite
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Save the following information for further usage:
The connection string for the Orchestrator database in the standalone deployment;
- The
test-automationdatabase connection string.
- The
The connection string for the Insights database in the standalone deployment;
AutomationSuite_Platformdatabase in the Automation Suite deployment. You can retrieve the connection string from thecluster_config.jsonfile, under theplatformparameter. -
The following Test Manager information from the
appsettings.production.jsonfile located in the Test Manager installation directory:Note:If the
appsettings.production.jsonfile is encrypted, you can use the Test Manager provisioning tool to decrypt it. For more information, visit Test Manager config file encryption.-
The connection string for the Test Manager database in the standalone deployment.
You can find the connection string in the following key:
Database.ConnectionString.testmanagementhub. -
The storage location information stored in the
Storage.Locationkey. -
The information stored in the
Security.DataEncryptionKeykey.
