- Overview
- Requirements
- Root privileges requirements
- High Availability – three availability zones
- Certificate Requirements
- Network Requirements
- Validating the Prerequisites in a Single-node Evaluation Setup
- Validating the Prerequisites in a Multi-node HA-ready Production Setup
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Before installing Automation Suite, it is good practice to validate the installation prerequisites and infrastructure readiness. You can use the dedicated script to evaluate your environment and generate a summary before performing the installation.
Using the script to validate installation prerequisites
Downloading the Script
For offline installations, you must perform this step on a machine with access to internet and to the air-gapped machines where Automation Suite is deployed. Copy the file from the online machine to the first target machine.
The prerequisite script is packaged along with the installer in an archive called sf-installer.zip, and supporting tools are bundled as sf-infra.tar.gz for offline only. You need these files to generate a report on all the machines on which you plan to install Automation Suite.
| Installation type | Files to download |
| Online | sf-installer.zip – Mandatory. For download instructions, see sf-installer.zip. |
| Offline | sf-installer.zip – Mandatory. For download instructions, see sf-installer.zip.sf-infra.tar.gz – Mandatory. For download instructions, see sf-infra.tar.gz. |
Preparing to Use the Script
Become root by running the following command:
sudo su -sudo su - -
Copy the files to the
/opt/UiPathAutomationSuite/{version}folder by running the following command:VERSION="" #add the version number you are trying to install. Ex: for 2022.4.0 Set VERSION="2022.4.0" mkdir -p /opt/UiPathAutomationSuite/${VERSION} # For below command replace the /path/to where actually the files are present. cp /path/to/sf-installer.zip /opt/UiPathAutomationSuite/${VERSION} # Additionally for offline, copy sf-infra.tar.gz as well to /opt/UiPathAutomationSuite/{VERSION} folder cp /path/to/sf-infra.tar.gz /opt/UiPathAutomationSuite/${VERSION} cd /opt/UiPathAutomationSuite/${VERSION}VERSION="" #add the version number you are trying to install. Ex: for 2022.4.0 Set VERSION="2022.4.0" mkdir -p /opt/UiPathAutomationSuite/${VERSION} # For below command replace the /path/to where actually the files are present. cp /path/to/sf-installer.zip /opt/UiPathAutomationSuite/${VERSION} # Additionally for offline, copy sf-infra.tar.gz as well to /opt/UiPathAutomationSuite/{VERSION} folder cp /path/to/sf-infra.tar.gz /opt/UiPathAutomationSuite/${VERSION} cd /opt/UiPathAutomationSuite/${VERSION} -
Unzip the package by running the following command:
unzip sf-installer.zip -d installerunzip sf-installer.zip -d installer -
Assign the necessary permissions and navigate to the script folder by running the following command:
chmod -R 755 installer cd installerchmod -R 755 installer cd installer
Script Parameters
To view the help section and supported flags, run the following command:
./validateUiPathASReadiness.sh --help
Output:
validateUiPathASReadiness.sh Runs pre-install validation checks
Arguments:
-i|--input Specify cluster config json file
-m|--machines Comma separated IP address / hostnames of all the machines
-n|--node-type Possible values [server|agent|task-mining|gpu]. Defaults to server
--install-type Possible values [online|offline]. Defaults to online
--install-standalone-aicenter Run checks for standalone aicenter service only
--prereq-bundle </uipath/sf-infra.tar.gz> Specify the path to the prereq bundle, only for offline installation
--prereq-tmp-folder </uipath> Specify parent directory for the temporary install folder, only for offline installation
-h|--help Display help
Arguments:
The following table describes the parameters you can use when running the script:
| Parameter | Description |
-i|--input | Accepts the cluster_config.json file as input. This file defines the parameters, settings, and preferences applied to the UiPath services deployed via Automation Suite. For details, see Advanced Installation Experience.If you do not provide this file, the script will trigger the interactive experience to collect these inputs. The file will then be generated on your behalf. |
-m|--machines | Accepts comma-separated IP address / hostnames of all the machines. This is required to check the connectivity between all the nodes on the required port. The parameter is mandatory for multi-node HA-ready production installations. In addition to that, the parameter is also required if you plan to add a Task Mining or GPU node in a single-node evaluation cluster. |
-n|--node-type | Accepts the type of the current node. Possible values are: server, agent, task-mining, and gpu.The default value is server. |
--install-type | Accepts the installation method: online or offline.The default value is online. |
--install-standalone-aicenter | This is a Boolean flag. Pass it if you plan to install standalone AI Center. |
--prereq-bundle | Accepts the absolute path where the sf-infra.tar.gz is located. |
--prereq-tmp-folder | Accepts the absolute path where sf-infra.tar.gz bundle will be temporarily extracted. If this path is not provided, the installer will select the /tmp folder. |
Validating a multi-node HA-ready production setup
On the First Server Machine
- To validate the first server machine, run the following command:
Online
./validateUiPathASReadiness.sh \
--node-type server \
--install-type online \
--machines "10.0.1.8, 10.0.1.9" #replace with actual machine IPs of all the nodes in cluster
Offline
--install-type offline \
--prereq-bundle ../sf-infra.tar.gz \
--prereq-tmp-folder /opt/UiPathAutomationSuite/tmp \
Once this script is executed, it generate sa cluster_config.json file under the /opt/UiPathAutomationSuite folder. This file is required on all the other machines.
- To copy the
cluster_config.jsonfile on the other machines, run the following command:
scp /opt/UiPathAutomationSuite/cluster_config.json <username>@<node dns>:/opt/UiPathAutomationSuite
If you cannot copy the file to the /opt/UiPathAutomationSuite folder due to permission errors, you can temporarily copy it to /var/tmp on the new machines, and then move it to /opt/UiPathAutomationSuite.
Alternatively, you can also provide full access permissions (777) to the /opt/UiPathAutomationSuite folder on the new machines, by running the following command: chmod -R 777 /opt/UiPathAutomationSuite.
On the Other Server Machines
To validate the other server machines, run the following command:
Online
--input /opt/UiPathAutomationSuite/cluster_config.json \
--machines "10.0.1.8, 10.0.1.9" #replace with actual machine IP of all the nodes in cluster
Offline
On Agent Machines
To validate the agent machines, run the following command:
Online
--node-type agent \
--machines "10.0.1.8, 10.0.1.9" # replace with actual machine IP of all the nodes in cluster
--node-type agent \
Offline
--node-type agent \
--install-type offline \ #replace with offline for airgap
--node-type agent \
On Task Mining Machines & GPU Machines
To validate the Task Mining & GPU machines, run the following command:
For Task Mining and GPU nodes, use --node-type task-mining and --node-type gpu, respectively, in the following commands.
Online
./validateUiPathASReadiness.sh \)\)
--input /opt/UiPathAutomationSuite/cluster_config.json \)\)
--node-type task-mining \)\) #replace with GPU for GPU node
--install-type online \)\)
Offline
--install-type offline \)\)
--prereq-bundle ../sf-infra.tar.gz \)\)
--prereq-tmp-folder /opt/UiPathAutomationSuite/tmp \)\)
