- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Audit Logs Queries
- MongoDB Monitoring Dashboard
- MongoDB Certificate Renewal
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
MongoDB uses two types of certificates for a secure connection within the Automation Suite cluster:
- CA root certificate
- TLS certificate
Starting with 2022.4.0, the MongoDB certificates generated during installation are valid for three years.
For environments upgraded from versions before 2021.10.3 to 2022.4, follow the steps described in this page for MongoDB certificate rotation. The generated MongoDB certificates are valid for three years.
For fresh 2022.4 installations and onward, the certificate rotation is done automatically. The CA certificate is renewed automatically 30 days before it expires, while the TLS certificate is renewed 20 days before it expires. Because of this, there is no user intervention needed to maintain the validity of the certificates.
However, if you want to renew the certificates manually, you can use the certificate rotation CLI. Follow the steps below to run the certificate rotation.
The certificate rotation script takes around 5-10 minutes to complete. The new certificates generated by the script are valid for three years from the time of creation and are automatically renewed as per the timeline mentioned above.
