Automation Suite
- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- GPU node affected by resource unavailability
- RKE2 not getting started due to space issue
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated Apr 24, 2024
During the automated upgrade from Automation Suite 2021.10, the CNI provider is migrated from Canal to Cilium. This operation requires that all nodes are restarted. On rare occasions, one or more nodes might not be successfully rebooted, causing pods running on those nodes to remain unhealthy.
Identify failed restarts.
During the Ansible execution, you might see output similar to the following snippet:
TASK [Reboot the servers] *************************************************************************************************************************** fatal: [10.0.1.6]: FAILED! => msg: 'Failed to connect to the host via ssh: ssh: connect to host 10.0.1.6 port 22: Connection timed out'
TASK [Reboot the servers] *************************************************************************************************************************** fatal: [10.0.1.6]: FAILED! => msg: 'Failed to connect to the host via ssh: ssh: connect to host 10.0.1.6 port 22: Connection timed out'Alternatively, browse the logs on the Ansible host machine, located at/var/tmp/uipathctl_<version>/_install-uipath.log
. If any failed restarts were identified, execute steps 2 through 4 on all nodes. -
Confirm a reboot is needed on each node.
Connect to the each node and run the following command:
ssh <username>@<ip-address> iptables-save 2>/dev/null | grep -i cali -c
ssh <username>@<ip-address> iptables-save 2>/dev/null | grep -i cali -cIf the result is not zero, a reboot is needed.
Reboot the node:
sudo reboot
sudo reboot - Wait for the node to become responsive (you should be able to SSH to it) and repeat steps 2 through 4 on every other node.
