- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Automation Suite overview
Automation Suite capabilities, product offerings, and Linux-based deployment architecture for self-hosted UiPath automation.
This page outlines the capabilities and product offerings you can enjoy if you install Automation Suite, and helps you get an idea about the architecture you are about to build.
Automation Suite enables you to deploy the full UiPath® automation platform in a Linux environment ranging from bare metal machines to on-premises Virtual Machine infrastructure, or cloud subscriptions to any of the major providers.
Managing multiple server product deployments independently usually requires configuring integrations with enterprise systems for authenticating and managing users, as well as managing and monitoring each deployment from an availability and scale perspective.
Automation Suite contains everything in one package that you can deploy in multi-node HA-ready production mode with automatic scaling and built-in HA, and monitor, configure, and upgrade as a whole. All the functionality available in Automation Cloud is adapted to make it easier for you to manage everything yourself with low total cost of ownership.
What Automation Suite includes:
- All Server Products (except for any new products shipping in Automation Cloud first).
- All shared suite capabilities that enable you to configure the integration with existing enterprise systems, such as Active Directory (AD), Microsoft Entra ID, or SAML, across all products. A common experience is offered across the suite for the user, tenant, external applications, and license management.
- Common end user portal.
- Kubernetes-based infrastructure, cluster management, and monitoring tools, all preconfigured, dedicated to and optimized for UiPath®. This enables running all the products at scale and with HA. This means you do not have to design, configure, and validate which Kubernetes versions and components for routing, storage, etc., work well with the UiPath® services.
Everything needed is included and optimized, all supported by UiPath®.
You just need to bring the machines, load balancer, and SQL. For the specific requirements for the machines as well as installation options and instructions, see and the remaining of this section.
For a leaner stack, reduced complexity, and more streamlined operations, Automation Suite is available for containerized platforms as well:
- If you are interested in deploying Automation Suite in an AKS or EKS environment, refer to Automation Suite on EKS/AKS Installation Guide.
- If you are interested in deploying Automation Suite in an OpenShift environment, refer to Automation Suite on OpenShift Installation Guide.
For an in-depth perspective on each deployment model, refer to Cross-deployment model feature comparison.
Key benefits
The following image shows an overview of Automation Suite key benefits and capabilities.
Deployment Scenarios
- Online single-node evaluation
- Online multi-node lite mode
- Online multi-node HA-ready production
- Offline single-node evaluation
- Offline multi-node lite mode
- Offline multi-node HA-ready production
High Availability
We are enabling high availability (HA) by default for multi-node HA-ready production mode as part of the offering. This is enabled as part of the cluster_config.json configuration at installation time. We also support the ability to add more nodes to either single-node evaluation or multi-node HA-ready production configurations to scale out. However, we do not support going from non-HA to HA mode.
Insights does not support HA.
Upgrade
The upgrade process covers both the infrastructure and the entire UiPath® automation platform.
Cluster management
We are using Rancher as the UI layer for managing our cluster. The UI provides a cluster explorer to manage the deployment.
Monitoring
The platform exposes Grafana, Prometheus, and Alertmanager by default for troubleshooting and monitoring. See how to monitor the cluster, set alerts, create and view dashboards to track the deployment in the Rancher documentation.
For details, refer to Monitoring Stack for UiPath Automation Suite.
Support Bundle
Support Bundle tool collects logs from the in-cluster object/blob store, logs from currently running pods (of last four hours), different events, and Kubernetes object definitions.
For details on how to use the tool, refer to Support Bundle.
Backup and restore
The suite supports backup and recovery for the entire cluster except for external data sources, such as SQL Server.
Cluster backup is enabled by default every 15 minutes.
For details, refer to Backing up and restoring the cluster.
SQL authentication methods
The suite supports both SQL authentication and Kerberos authentication for all SQL database connections.
Integration Service does not support Kerberos authentication.
Product offering
Learn more about Automation Suite products.
Evaluation guide
Requirements and installation
Make sure you meet the following requirements before installing Automation Suite.
Platform evaluation
The following table describes the platform evaluation resources for Automation Suite.
| Details | Instructions |
| Complete an initial platform configuration. | Automation Suite Configuration checklist |
| Connect your first robot. | Connecting Attended Robots |
| Monitor the stack, troubleshoot issues, create alerts, and view dashboards from a centralized location. | Using the Diagnostics Tool Using the Support Bundle tool Monitoring Automation Suite Alerts |
Product evaluation
The following instructions take you to the corresponding product guides.
| Product | Evaluation checklist |
| Orchestrator | Orchestrator configuration checklist |
| Automation Suite Robots | Automation Suite Robots configuration checklist |
| Automation Hub | Automation Hub configuration checklist |
| Automation Ops | Automation Ops configuration checklist |
| Test Manager | Test Manager configuration checklist |
| AI Center | AI Center configuration checklist |
| Action Center | Action Center configuration checklist |
| Apps | Apps configuration checklist |
| Insights | Insights configuration checklist |
| Data Service | Data Service configuration checklist |
| Process Mining | Process Mining configuration checklist |
| Document Understanding | Document Understanding AI Center-based projects configuration checklist Document Understanding modern projects configuration checklist |
| Integration Service | Integration Service configuration checklist |
| Solutions | Solutions configuration checklist |
