Disaster Recovery: Performing post-installation operations
Reference for disaster recovery post-installation operations and kubeconfig generation in Automation Suite.
Generating the kubeconfig file of the cluster
The generated kubeconfig file must have only limited permissions to access another cluster's correct set of Kube objects.
To generate the base64-encoded kubeconfig file, run the following command:
./bin/uipathctl config kubeconfig get --multisite
  • --multisite: Generates the kubeconfig file with limited permissions.
Updating the kubeconfig file and linking two Automation Suite clusters
To update the kubeconfig file of another cluster and link both of them, run the following command:
./bin/uipathctl config kubeconfig set --secret "fgad8GDH9dbks" --multisite
  • --secret: Accepts the base64-encoded kubeconfig file.
  • --multisite: Links the two clusters.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
