Upgrade fails due to unhealthy Ceph
Verify and repair Ceph object store health before upgrading Automation Suite on Linux.
When trying to upgrade to a new Automation Suite version, you might see the following error message: Ceph objectstore is not completely healthy at the moment. Inner exception - Timeout waiting for all PGs to become active+clean.
Solution
To fix this upgrade issue, verify if the OSD pods are running and healthy by running the following command:
kubectl -n rook-ceph get pod -l app=rook-ceph-osd  --no-headers | grep -P '([0-9])/\1'  -v
  • If the command does not output any pods, verify if Ceph placement groups (PGs) are recovering or not by running the following command:
    function is_ceph_pg_active_clean() {
      local return_code=1
      if kubectl -n rook-ceph exec  deploy/rook-ceph-tools -- ceph status --format json | jq '. as $root | ($root | .pgmap.num_pgs) as $total_pgs | try ( ($root | .pgmap.pgs_by_state[] | select(.state_name == "active+clean").count)  // 0) as $active_pgs | if $total_pgs == $active_pgs then true else false end' | grep -q 'true';then
        return_code=0
      fi
      [[ $return_code -eq 0 ]] && echo "All Ceph Placement groups(PG) are active+clean"
      if [[ $return_code -ne 0 ]]; then
        echo "All Ceph Placement groups(PG) are not active+clean. Please wait for PGs to become active+clean"
        kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph pg dump --format json | jq -r '.pg_map.pg_stats[] | select(.state!="active+clean") | [.pgid, .state] | @tsv'
      fi
      return "${return_code}"
    # Execute the function multiple times to get updated ceph PG status
      local return_code=1
        return_code=0
      fi
      fi
    Note:
    If none of the affected Ceph PG recovers even after waiting for more than 30 minutes, raise a ticket with UiPath® Support.
  • If the command outputs pod(s), raise a ticket with UiPath® Support.
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
