- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Enable Istio access logging for debugging in Automation Suite on Linux.
To debug Istio, you need to enable logging. To do that, perform the following steps:
Edit the
istioconfigmap inistio-systemnamespace, by using the following command:kubectl edit cm -n istio-system istiokubectl edit cm -n istio-system istio -
Under
data.mesh, add the following fields:accessLogFile: /dev/stdout logLevel: debug accessLogEncoding: "JSON"accessLogFile: /dev/stdout logLevel: debug accessLogEncoding: "JSON"The following sample is an example of an updated
istioconfigmap:apiVersion: v1 data: mesh: |- accessLogFile: /dev/stdout logLevel: debug accessLogEncoding: "JSON" accessLogFormat: | { "start_time": "%START_TIME%", "trace_parent": "%REQ(TRACEPARENT)%", "method": "%REQ(:METHOD)%", "path": "%REQ(X-ENVOY-ORIGINAL-PATH?:PATH)%", "protocol": "%PROTOCOL%", "response_code": "%RESPONSE_CODE%", "response_flags": "%RESPONSE_FLAGS%", "bytes_received": "%BYTES_RECEIVED%", "bytes_sent": "%BYTES_SENT%", "duration": "%DURATION%", "upstream_service_time": "%RESP(X-ENVOY-UPSTREAM-SERVICE-TIME)%", "x_forwarded_for": "%REQ(X-FORWARDED-FOR)%", "user_agent": "%REQ(USER-AGENT)%", "request_id": "%REQ(X-REQUEST-ID)%", "authority": "%REQ(:AUTHORITY)%", "upstream_host": "%UPSTREAM_HOST%" } defaultConfig: discoveryAddress: istiod.istio-system.svc:15012 image: imageType: distroless proxyMetadata: WASM_INSECURE_REGISTRIES: '*' defaultProviders: metrics: - prometheus enablePrometheusMerge: true extensionProviders: - envoyExtAuthzHttp: includeHeadersInCheck: - authorization - cookie port: 80 service: auth-oauth2-proxy.uipath.svc.cluster.local name: oauth2-proxy rootNamespace: istio-system trustDomain: cluster.local meshNetworks: 'networks: {}' kind: ConfigMap metadata: annotations: meta.helm.sh/release-name: istiod meta.helm.sh/release-namespace: istio-system labels: app.kubernetes.io/managed-by: Helm install.operator.istio.io/owning-resource: unknown istio.io/rev: default operator.istio.io/component: Pilot release: istiod name: istio namespace: istio-system resourceVersion: "180392" uid: 30647d4d-f62a-477e-ad80-c98a93f48855apiVersion: v1 data: mesh: |- accessLogFile: /dev/stdout logLevel: debug accessLogEncoding: "JSON" accessLogFormat: | { "start_time": "%START_TIME%", "trace_parent": "%REQ(TRACEPARENT)%", "method": "%REQ(:METHOD)%", "path": "%REQ(X-ENVOY-ORIGINAL-PATH?:PATH)%", "protocol": "%PROTOCOL%", "response_code": "%RESPONSE_CODE%", "response_flags": "%RESPONSE_FLAGS%", "bytes_received": "%BYTES_RECEIVED%", "bytes_sent": "%BYTES_SENT%", "duration": "%DURATION%", "upstream_service_time": "%RESP(X-ENVOY-UPSTREAM-SERVICE-TIME)%", "x_forwarded_for": "%REQ(X-FORWARDED-FOR)%", "user_agent": "%REQ(USER-AGENT)%", "request_id": "%REQ(X-REQUEST-ID)%", "authority": "%REQ(:AUTHORITY)%", "upstream_host": "%UPSTREAM_HOST%" } defaultConfig: discoveryAddress: istiod.istio-system.svc:15012 image: imageType: distroless proxyMetadata: WASM_INSECURE_REGISTRIES: '*' defaultProviders: metrics: - prometheus enablePrometheusMerge: true extensionProviders: - envoyExtAuthzHttp: includeHeadersInCheck: - authorization - cookie port: 80 service: auth-oauth2-proxy.uipath.svc.cluster.local name: oauth2-proxy rootNamespace: istio-system trustDomain: cluster.local meshNetworks: 'networks: {}' kind: ConfigMap metadata: annotations: meta.helm.sh/release-name: istiod meta.helm.sh/release-namespace: istio-system labels: app.kubernetes.io/managed-by: Helm install.operator.istio.io/owning-resource: unknown istio.io/rev: default operator.istio.io/component: Pilot release: istiod name: istio namespace: istio-system resourceVersion: "180392" uid: 30647d4d-f62a-477e-ad80-c98a93f48855 -
Restart the
istiodeployments, by using the following commands:kubectl rollout restart deploy/istiod -n istio-system kubectl rollout restart ds/istio-ingressgateway -n istio-systemkubectl rollout restart deploy/istiod -n istio-system kubectl rollout restart ds/istio-ingressgateway -n istio-system
