Upgrade failure due to uppercase hostname
Convert uppercase hostnames to lowercase or add node labels for Automation Suite upgrades on Linux.
An issue may cause the upgrade to fail when the upgrade process attempts to create the upgrade-server deployment on nodes that use uppercase hostnames. Kubernetes automatically converts the kubernetes.io/hostname label to lowercase, which creates a mismatch because the upgrade process uses the original system hostname.
Solution
To address the issue, use one of the following options:
  1. Manually edit the deployment and change the hostname label to lowercase.
  2. Add a node label that preserves the uppercase hostname, as shown in the following example:
    kubectl label node hostname-1
    kubernetes.io/hostname-upper=HOSTNAME-1
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
