Kerberos authentication configuration
Configure Kerberos authentication parameters in cluster_config.json for Automation Suite.
You can configure Kerberos authentication by editing the cluster_config.json file. For details on how to configure the required parameters within the cluster_config.json file, refer to Configuring Kerberos authentication via cluster_config.json.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
