- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Accessing the Models
- Enabling or disabling Extended Languages OCR
- Allocating GPU resources for Document Understanding modern projects
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Allocate GPU resources for Document Understanding modern projects in Automation Suite using ArgoCD parameters.
For optimal performance, allocating the appropriate number of GPU resources is vital. You allocate GPU resources through ArgoCD, which contains specific parameters that correspond to each service. By adjusting these parameters, you can control the distribution of GPU resources as per the needs of each service.
Each service listed in the capacity calculator has a corresponding ArgoCD parameter as follows:
- OCR replicas corresponds to the
du-ocr-saas.replicaCountparameter. - Custom model training replicas corresponds to the
du-training-ssde.replicasparameter. - Custom model replicas corresponds to the
du-aimodelhost-2404.replicasparameter. - OOB model replicas corresponds to the
du-ssde-saas.replicaCountparameter.
Before allocating of GPU resources to each service, use the capacity calculator to determine the appropriate number of GPUs that should be allocated to each service. The output is based on your specific needs and will serve as a guide when updating the parameters in ArgoCD.
For details, refer to the UiPath Automation Suite Install Sizing Calculator page.
For Document Understanding modern projects, the minimum recommended GPU is NVIDIA T4.
Open ArgoCD.
Select the documentunderstanding application.
Select Details to open the Details menu.
Select the Parameters tab.
Select Edit so you can edit the parameter values.
Search for the parameters that need to be edited and allocate the needed number of GPUs.
Each service listed in the capacity calculator has its corresponding ArgoCD parameter as follows:
Select Save.
