- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Overview of the Automation Suite upgrade process, prerequisites, and compatibility considerations.
If your host VM nodes use cgroup v1, you must migrate to cgroup v2 before upgrading to Automation Suite 2.2510.2. For details, refer to RHEL compatibility matrix and How to migrate to cgroup v2.
NFS server-based backups are not supported if you are using an external objectstore. Your backups are stored directly in the external objectstore. If you upgrade to 2.2510, you must switch to the external objectstore for backups.
Learn more about Configuring the external objectstore or reach out to support.
Task Mining is no longer available in Automation Suite 2.2510 (Release notes 2.2510.0). If Task Mining was installed in a previous version of Automation Suite, it will no longer be visible after upgrading to version 2.2510.
- Internally, Task Mining depended on the Dapr service, which also has been removed. After successfully upgrading or migrating from a version of Automation Suite that had Task Mining enabled, make sure to delete the Task Mining node, database, and storage, or adjust the nodes for internal use cases by updating taints and tolerations as needed.
Automation Suite 2023.4.5 and 2023.10.2 include an upgrade to Kubernetes 1.26.11. As such, when upgrading Automation Suite, you must ensure you do not downgrade Kubernetes. To do that, when moving from Automation Suite 2023.4.5 or a later minor version to the next major version, you must upgrade to 2023.10.2 at a minimum.
For the available upgrade paths, refer to Automation Suite upgrade paths.
If you plan to upgrade from Automation Suite 2022.10 or earlier, and Process Mining is enabled, you must migrate process apps to the new process graph layout before starting the upgrade.
If you upgrade from an Automation Suite version installed a machine with FIPS 140-2 disabled, you can enable FIPS 140-2 by following the instructions on Security and compliance.
You cannot enable or disable any product during an Automation Suite upgrade.
If you upgrade to Automation Suite 2.2510 and want to use Document Understanding modern projects, you must meet the additional hardware requirements we specify in Additional Document Understanding recommendations.
Upgrade your UiPath Automation Suite at least once a year. This keeps you on the latest supported Kubernetes versions, prevents the need for multi-hop intermediate upgrades, and allows smooth, direct jumps to new target versions.
Requirements
- Make sure you meet the hardware and software requirements for the new Automation Suite version. If AI Center is enabled, make sure you meet the CUDA requirements.
- Make sure you follow the Automation Suite upgrade best practices and perform the upgrade process that best suits your needs.
Upgrade process
Automation Suite supports two upgrade processes:
- In-place upgrade
- Side-by-side upgrade
In-place upgrade process
The Automation Suite in-place upgrade process allows you to move to a new Automation Suite version while keeping your settings and data intact on the same hardware.
- In the in-place upgrade process, you first upgrade Kubernetes and other infrastructure components sequentially to the target version.
- Following Kubernetes and other infrastructure component upgrades, you must uninstall the current version and install the target version of shared components and UiPath® products.
- In case of hard failure beyond recovery during the upgrade process, you need to roll back to the previous version using the backup and restore capability.
The Automation Suite side-by-side upgrade leverages an enterprise upgrade experience that is usually called blue-green and is a standard process across the industry.
- The side-by-side upgrade allows you to perform an upgrade safely using a parallel environment instead of upgrading in place.
- This method allows administrators to switch traffic from the old Automation Suite cluster (that is, the blue deployment) to the new Automation Suite cluster (that is, the green deployment) after verifying the new deployment. If you detect a problem, you can quickly roll back to the old deployment.
Upgrade mechanism and capabilities
| Capability | Upgrade mechanism | |
| In-place upgrade | Side-by-side upgrade | |
| Upgrade to a new LTS version | ✅ | ✅ |
| Upgrade from any supported version |
| ✅ 2 |
| High-fidelity data migration | ✅ | ❌ 3 |
| No downtime during upgrade | ❌ | ❌ |
| Instant rollback | ❌ | ✅ |
| No additional hardware requirements | ✅ | ❌ 4 |
1 You can upgrade from any Automation Suite version, but an intermediate upgrade between your initial and targeted versions might be needed. For details, refer to In-place upgrade paths.
2 You can upgrade from any Automation Suite version, except for 2021.10. For details, refer to Side-by-side upgrade paths.
3 For details, refer to Data migration and responsibilities.
4 Side-by-side upgrades require additional hardware. You can either bring a parallel environment with the same specifications as the source cluster or start with hardware required for a single-node cluster and scale it up.
The following matrix shows the available in-place upgrade paths for Automation Suite versions:
✅ - a direct in-place upgrade path between major versions is available;
- an intermediate in-place upgrade between your initial and targeted major versions is needed.Note:If you need to upgrade to an intermediate version, then you can use intermediate version as the base version to continue upgrading along the upgrade path.
In-place upgrade paths are specific to Automation Suite on Linux. For Automation Suite on EKS/AKS, on the one hand, you must maintain Kubernetes compatibility. For Automation Suite on OpenShift, on the other hand, you must maintain OpenShift compatibility.
We strongly advise upgrading to the most recent minor version of Automation Suite. This allows you to take advantage of the latest enhancements and guarantees the seamless operation of all internal components.
| Initial version | Automation Suite on Linux targeted version | ||||
| 2022.10.x | 2023.4.x | 2023.10.x | 2024.10.x | 2.2510.x | |
| 2021.10.x | ✅
| 2022.4.x | ✅
| ✅ Requires 2022.4.7 minimum with Ceph on raw devices, and completion of Cilium migration before initiating the upgrade.
| 2022.10.x | ✅
| 2023.4.x | N/A | ✅
| 2023.10.x | N/A | N/A | ✅
| 2024.10.x | N/A | N/A | N/A | ✅
| 2.2510.x | N/A | N/A | N/A | N/A | ✅
- In some cases, upgrading Automation Suite requires transitioning through an intermediate version or skiping some versions entirely to maintain the smooth functioning of the internal components. Not following the upgrade guidelines in the previous table may lead to an internal component downgrade or an unsuccessful internal component upgrade, thereby causing the Automation Suite upgrade to fail.
- If you plan to upgrade from Automation Suite 2022.10 or earlier, and Process Mining is enabled, you must migrate process apps to the new process graph layout before starting the upgrade.
- If you use Active Directory (AD) and are planning on upgrading to 2023.4.0, we highly recommend that you skip straight to the 2023.4.3 version, as 2023.4.0, 2023.4.1 and 2023.4.2 are impacted by an AD issue.
- Only upgrades to Automation Suite 2023.10 and later leverage the simplified upgrade process.
The following matrix shows the available side-by-side upgrade paths for Automation Suite versions:
- ✅ - a direct side-by-side upgrade path between versions is available;
- ❌ - a side-by-side upgrade between your initial and targeted versions is not possible.
Note:
| Initial version | Targeted version | ||||||
| 2021.10.x | 2022.4.x | 2022.10.x | 2023.4.x | 2023.10.x | 2024.10.x | 2.2510.x | |
| 2021.10.x | ❌ | ❌ | ❌ | ❌ | ❌ | ❌ | ❌ |
| 2022.4.x | N/A | ❌ | ❌ | ❌ | ✅ | ✅ | ❌ |
| 2022.10.x | N/A | N/A | ❌ | ❌ | ✅ | ✅ | ✅ |
| 2023.4.x | N/A | N/A | N/A | ❌ | ✅ | ✅ | ✅ |
| 2023.10.x | N/A | N/A | N/A | N/A | ✅ | ✅ | ✅ |
| 2024.10.x | N/A | N/A | N/A | N/A | N/A | ✅ | ✅ |
| 2.2510.x | N/A | N/A | N/A | N/A | N/A | N/A | ✅ |
Upgrade best practices
If you can bring an additional environment to perform the upgrade, we recommend choosing the side-by-side upgrade path as it provides a safer upgrade approach and instant rollback.
If you cannot bring an additional environment to perform the upgrade, you can opt for the in-place upgrade. Make sure to follow the upgrade validation best practices.
Upgrade validation best practices
Environments
We recommend preparing two similar Automation Suite environments, regardless of whether you want to use the in-place or side-by-side upgrade:
Automation Suite multi-node cluster for dev or QA
Note:The dev/QA environment does not need to be online all the time if not used for anything else than upgrade validation.
Automation Suite multi-node cluster for production
Backup
It is strongly recommended to create a backup of the cluster and the SQL database before upgrading Automation Suite. This is to ensure you can restore the cluster if something goes wrong during the upgrade operation.
Cluster data is backed up on the NFS server. Make sure you have configured the NFS server before proceeding.
Very large Automation Suite database tables can cause database migration jobs to take much longer or fail to complete during the upgrade. Keeping database tables well-maintained reduces this risk.
We recommend archiving or purging data that is no longer needed from high-volume tables before starting the upgrade; for details, refer to Performing database maintenance.
Authentication
Make sure to copy the value of global.userInputs.identity.krb5KeytabSecret to global.kerberosAuthConfig.userKeytab if you simultaneously meet the following requirements:
- You configured the Active Directory integration using username and password;
- You have Windows authentication enabled;
- You do not use SQL integrated authentication.
Automation validation best practices
To validate the automations that you built, create separate organizations or tenants directly in your Automation Suite production environment, as it is the most cost-effective solution. For more best practices, refer to Orchestrator - Automation Best Practices.
Version validation
To validate your automations in different environments and versions, leverage your second Automation Suite cluster after installing the new Automation Suite cluster but before switching the traffic to the new cluster in production.
Licensing
Upgrading to a new Automation Suite version does not require an additional license, regardless of which upgrade path you choose. However, if you follow our best practices, and use two Automation Suite clusters (one for QA/dev, and another for production), you need a license per cluster.
- Requirements
- Upgrade process
- In-place upgrade process
- Upgrade mechanism and capabilities
- In-place upgrade paths
- Side-by-side upgrade paths
- Upgrade best practices
- Upgrade validation best practices
- Environments
- Backup
- Authentication
- Automation validation best practices
- Version validation
- Licensing
