- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Reference for IAM roles and policies created by the CloudFormation template for Automation Suite on AWS Marketplace.
The the following table describes the IAM roles and policies that the CloudFormation template creates:
| Role | Actions |
This role is used to copy objects between S3 buckets. It is a copy of the https://github.com/aws-quickstart/lambda-copyzips AWS repository initially used for the AWS QuickStart. copy-zips.template.yaml |
The purpose of this role is to create and verify an ACM certificate using DNS validation and Route 53. It is a copy of the https://github.com/aws-quickstart/quickstart-aws-acm-certificate AWS repository used for the AWS QuickStart. quickstart-aws-acm-certificate.template.yml |
DeliverLogsPermissionArn parameter in the AWS::EC2::FlowLog resource type. Is it a copy of the https://github.com/aws-quickstart/quickstart-aws-vpc QuickStart repository. File: aws-vpc.template.yaml |
AWS::SSM::Document ), with the following purposes:
File: |
OnDemandRestoreStateMachine resource ( AWS::StepFunctions::StateMachine ). This resource is used for the restore operation. File: | Uses the AmazonSSMFullAccess managed policy. |
AWS::Events::Rule ):
The rules are for the terminate lifecycle action. File: |
ObjectStorageBucketsCleanupFunction lambda function and provides utility for the object storage. File: |
This role is referenced in the following resources:
File: | Uses the AmazonSSMManagedInstanceCore managed policy. |
This role is used to modify the ASG processes during CF stack creation. File: |
FindAMIFunction lambda function. File: |
CreateInputJsonFunction lambda function. The function creates the configuration file for the Automation Suite installation. File: |
ComputeResourceSizeFunction lambda function. The function validates that the input for resources is in accordance with the hardware requirements. File: |
| Policy | Actions |
Policy for log access. |
Policy for lifecycle hook access. |
Policy for EC2 and ASG access. |
Policy for getting access to the QS S3 bucket. |
Policy for allowing access to the secret manager. |
Policy for allowing access to SSM parameters. |
Policy for allowing access to external storage. |
