How to clear Redis data
Clear all data in Redis cluster using FLUSHALL commands for Automation Suite on Linux.
To clear all the data stored in Redis and reset it to an empty state, take the following steps:
  1. Identify the secret name, password, and port:
    export KUBECONFIG="/etc/rancher/rke2/rke2.yaml"; export PATH=$PATH:/var/lib/rancher/rke2/bin;
    secretName=$(kubectl get redb redis-cluster-db -o jsonpath="{.spec.databaseSecretName}" -n redis-system)
    password=$(kubectl get secret $secretName -o jsonpath="{.data.password}" -n redis-system | base64 --decode)
    port=$(kubectl get secret $secretName -o jsonpath="{.data.port}" -n redis-system | base64 --decode)
  2. Identify the service names:
    kubectl get secret $secretName -o jsonpath="{.data.service_names}" -n redis-system | base64 --decode
  3. Let's assume the output of the previous command is: redis-cluster-db, redis-cluster-db-headless. You must call the following FLUSHALL commands:
    kubectl exec -ti -n redis-system redis-cluster-0 -- redis-cli -h redis-cluster-db -p $port -a $password FLUSHALL
    kubectl exec -ti -n redis-system redis-cluster-0 -- redis-cli -h redis-cluster-db-headless -p $port -a $password FLUSHALL
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
