- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
NLog configuration options and supported logging extensions for Orchestrator in Automation Suite.
Adding NLog extensions
Orchestrator loads the following extensions by default, so you do not need to include them in the folder or the NLog configuration:
NLog.Targets.ElasticSearchUiPath.Orchestrator.Logs.ElasticsearchMicrosoft.ApplicationInsights.NLogTargetNLog.Extensions.AzureEventHub
Only Linux-compatible extensions can be used in this setup, so make sure that your chosen NLog extension abides by this rule.
To make the extension available for use, it must uploaded to the cluster storage. The uipathctl command line tool can do this via the uipathctl config orchestrator upload command:
./bin/uipathctl config orchestrator upload --nlog-extensions-directory /path/to/extensions/directory
If you use an external storage configuration at the cluster level, you must indicate this by including the --is-external-storage parameter.
Advanced NLog configuration
Creating the advanced NLog configuration
Create the
nlog.config.jsonfile containing the standard sections: extensions, targets and rules.The extensions section is an array of items that specify the extension assemblies, via
assemblyFile, and the path of the assembly.If custom NLog plugins were loaded (as described in the Adding NLog extensions section), they will be referenced in the
extensionssection. -
Configure the target and rule in the
nlog.config.jsonfile. -
Apply the
nlog.config.jsonfile using theuipathctlcommand line tool:./bin/uipathctl config orchestrator update-config --nlog-config nlog.custom.json./bin/uipathctl config orchestrator update-config --nlog-config nlog.custom.jsonImportant:This action overwrites the existing custom NLog configuration. You can check what the existing configuration is by using this command:
./bin/uipathctl config orchestrator get-config --nlog-config./bin/uipathctl config orchestrator get-config --nlog-configExample
nlog.config.jsonfile that writes logs to Azure Blob:{ "NLog": { "extensions": [ { "assemblyFile": "NLog.Extensions.AzureBlobStorage.dll" } ], "targets": { "azureBlob": { "type": "AzureBlobStorage", "connectionString": "DefaultEndpointsProtocol=https;AccountName=test;AccountKey=key;EndpointSuffix=core.windows.net", "container": "orchestratorlogs", "blobName": "${date:format=yyyy-MM-dd hh.mm}", "layout": { "type": "JsonLayout", "includeAllProperties": true, "Attributes": [ {"name": "ts","layout": "${longdate}"}, {"name": "level","layout": "${level:upperCase=true}"}, {"name": "logger","layout": "${logger}"}, {"name": "message","layout": "${message}"}, {"name": "exception","layout": "${onexception:${ui-pretty-exception}}"} ] } } }, "rules": { "70_Final": { "writeTo": "stdout,azureBlob" } } } }{ "NLog": { "extensions": [ { "assemblyFile": "NLog.Extensions.AzureBlobStorage.dll" } ], "targets": { "azureBlob": { "type": "AzureBlobStorage", "connectionString": "DefaultEndpointsProtocol=https;AccountName=test;AccountKey=key;EndpointSuffix=core.windows.net", "container": "orchestratorlogs", "blobName": "${date:format=yyyy-MM-dd hh.mm}", "layout": { "type": "JsonLayout", "includeAllProperties": true, "Attributes": [ {"name": "ts","layout": "${longdate}"}, {"name": "level","layout": "${level:upperCase=true}"}, {"name": "logger","layout": "${logger}"}, {"name": "message","layout": "${message}"}, {"name": "exception","layout": "${onexception:${ui-pretty-exception}}"} ] } } }, "rules": { "70_Final": { "writeTo": "stdout,azureBlob" } } } }Example
nlog.config.jsonfile that writes robot logs to Splunk:{ "Nlog": { "extensions": [ { "assemblyFile": "NLog.Targets.Splunk.dll" }, { "assembly": "UiPath.Orchestrator.Logs.DatabaseBulk.NLogTarget" } ], "targets": { "Splunk": { "type": "AsyncWrapper", "overflowAction": "Discard", "queueLimit": 10000, "batchSize": 200, "timeToSleepBetweenBatches": 1, "target": { "type": "SplunkHttpEventCollector", "serverUrl": "http://splunk.example.com", "token": "splunk-token", "channel": "", "source": "${logger}", "sourceType": "_json", "index": "uipath", "retriesOnError": "0", "batchSizeBytes": "0", "batchSizeCount": "0", "includeEventProperties": "true", "includePositionalParameters": "true", "includeMdlc": "true", "maxConnectionsPerServer": "10", "ignoreSslErrors": "false", "useProxy": "false", "proxyUrl": "", "proxyPassword": "" } } }, "rules": { "20_Robot_Primary": { "writeTo": "Splunk,database,insightsRobotLogs" } } } }{ "Nlog": { "extensions": [ { "assemblyFile": "NLog.Targets.Splunk.dll" }, { "assembly": "UiPath.Orchestrator.Logs.DatabaseBulk.NLogTarget" } ], "targets": { "Splunk": { "type": "AsyncWrapper", "overflowAction": "Discard", "queueLimit": 10000, "batchSize": 200, "timeToSleepBetweenBatches": 1, "target": { "type": "SplunkHttpEventCollector", "serverUrl": "http://splunk.example.com", "token": "splunk-token", "channel": "", "source": "${logger}", "sourceType": "_json", "index": "uipath", "retriesOnError": "0", "batchSizeBytes": "0", "batchSizeCount": "0", "includeEventProperties": "true", "includePositionalParameters": "true", "includeMdlc": "true", "maxConnectionsPerServer": "10", "ignoreSslErrors": "false", "useProxy": "false", "proxyUrl": "", "proxyPassword": "" } } }, "rules": { "20_Robot_Primary": { "writeTo": "Splunk,database,insightsRobotLogs" } } } }
Sizing the Splunk queueLimit
The queue absorbs Splunk backlog during slowdowns. Size it to your peak throughput, not your average:
queueLimit = peak_logs_per_sec × acceptable_backlog_seconds
| Deployment | Peak rate | Backlog tolerance | queueLimit |
| Small | ~10 logs/sec | 60 s | 600 |
| Medium | ~35 logs/sec | 300 s | 10000 |
| Large | ~200 logs/sec | 60 s | 12000 |
Best practices for Splunk targets
- Use
overflowAction: Discardfor secondary targets. External log targets such as Splunk are typically analytics or observability destinations, the Orchestrator database is the source of truth. If the external target cannot keep up, dropping its copy is preferable to blocking application threads. - Reserve
overflowAction: Blockfor targets where loss is not acceptable.Blockprevents event loss but does not prevent blocking. When the queue fills under sustained load it reverts to the same thread-blocking behavior asBufferingWrapper. Only use it when the external target is a compliance or audit requirement, and sizequeueLimitgenerously to match peak throughput. - Always keep
databasein thewriteTorule alongside any external target. This ensures no robot log is permanently lost regardless of the availability or performance of the external target. - Flush before shutdown.
AsyncWrapperholds events in an in-memory queue. Ensure NLog targets are flushed on graceful shutdown to avoid losing the tail of the queue when the process exits.
Updating the advanced NLog configuration
The uipathctl commands needed for updating the NLog configuration are:
./bin/uipathctl config orchestrator get-config --nlog-config- Exports the current configuration in a key-value pair json file, ready for editing../bin/uipathctl config orchestrator update-config --nlog-config nlog.config.json- Updates the configuration with your changes.
Export the current custom NLog configuration to a json file using this command:
./bin/uipathctl config orchestrator get-config --nlog-config > nlog.config.json./bin/uipathctl config orchestrator get-config --nlog-config > nlog.config.json -
Edit the exported
nlog.config.jsonfile as needed. You can add, remove, or change any of its settings.Note:You must export the file again every time you need to make a change, since the update overwrites all NLog settings.
Update the NLog configuration using this command:
./bin/uipathctl config orchestrator update-config --nlog-config nlog.config.json orchestrator config updated./bin/uipathctl config orchestrator update-config --nlog-config nlog.config.json orchestrator config updated
