- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Remapping the organization IDs
- Migrating Looker data to Automation Suite
- Performing Insights database maintenance
- Configuring log rules
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Migrate Looker data from Insights Standalone to Insights running in Automation Suite.
Use this procedure to migrate Looker data from Insights Standalone to Insights Automation Suite.
Step 1: Create Backup TAR File From Insights Linux Server
Open an SSH client and run the following command to authenticate.
ssh <username>@<hostname>ssh <username>@<hostname> -
Create a backup.
image=$(sudo docker container inspect looker-container -f '{{ .Image }}') backupPath="$HOME/insights/backup" && mkdir "$backupPath" -p sudo docker run -u root --rm --platform linux --volumes-from looker-container -v "$backupPath":/backup "$image" bash -c "tar cvf /backup/looker_backup.tar --absolute-names /app/workdir/.db /mnt/lookerfiles /app/workdir/looker.key"image=$(sudo docker container inspect looker-container -f '{{ .Image }}') backupPath="$HOME/insights/backup" && mkdir "$backupPath" -p sudo docker run -u root --rm --platform linux --volumes-from looker-container -v "$backupPath":/backup "$image" bash -c "tar cvf /backup/looker_backup.tar --absolute-names /app/workdir/.db /mnt/lookerfiles /app/workdir/looker.key"Note:Starting with the 2022.10 version, the
looker.keyis included in the migration backup. -
Exit the SSH.
exitexit -
Copy the files to the local machine using Secure Copy Protocol (SCP).
scp <username>@<hostname>:~\insights\backup\looker_backup.tar <path-to-download-dir>scp <username>@<hostname>:~\insights\backup\looker_backup.tar <path-to-download-dir>
Step 2: Restore Looker
Download the
kubeconfigfile. The following screenshot shows an Azure deployment template for Automation Suite. -
Open an SSH client and run the following command to get the Insights Looker pod name:
$Env:KUBECONFIG="C:\Users\username\Downloads\output.yaml" # path to the optput.yaml kubectl get pods -n uipath$Env:KUBECONFIG="C:\Users\username\Downloads\output.yaml" # path to the optput.yaml kubectl get pods -n uipath -
The Insights Looker pod is now listed (e.g.,
insights-insightslooker-c987df55c-gngqd). -
Set a variable name for the Insights Looker pod.
$PodName = "insights-insightslooker-74db798bc5-dt68p"$PodName = "insights-insightslooker-74db798bc5-dt68p" -
Create a backup for the Automation Suite data. The backup file will be stored on a machine with console where command is initiated. Please make sure to delete created backup because it contains sensitive information.
kubectl cp ${PodName}:/app/workdir/.db/ .\sf_db_backup -n uipath -c insightslooker kubectl cp ${PodName}:/mnt/lookerfiles/ .\sf_lookerfiles_backup -n uipath -c insightslookerkubectl cp ${PodName}:/app/workdir/.db/ .\sf_db_backup -n uipath -c insightslooker kubectl cp ${PodName}:/mnt/lookerfiles/ .\sf_lookerfiles_backup -n uipath -c insightslooker -
Unzip the TAR file from the Insights Linux Server.
7z x .\looker_backup.tar -olooker_backup # looker_backup is the output folder7z x .\looker_backup.tar -olooker_backup # looker_backup is the output folder -
(Conditionally required if the Automation Suite password is different from the one used in the Standalone deployment model) Edit the following files before the migration and update url and/or password in both looker.log and looker.script files.
Open
sf_db_backup/looker.logand search forhost_urlto find the string that starts withhttps://.Search for
INSERT INTO "CREDENTIALS_EMAIL" VALUES(1,1,'admin@uipath.com'insf_db_backup/looker.log.Copy the string that starts with
$2a$12$and overwrite all occurrences inlooker_backup/app/.db/looker.log.Note:- Turn off regex in the editor if you cannot find these lines.
- If there are multiple occurrences of
INSERT INTO "CREDENTIALS_EMAIL" VALUES(1,1,'admin@uipath.com'you need to update all of them.
Change the working directory to the
looker_backupfolder. In this folder you will see two sub-folders namedappandmnt.cd looker_backupcd looker_backup -
Copy files to the insights Looker pod and then restart the deployment.
kubectl cp .\app\workdir ${PodName}:/app -n uipath -c insightslooker kubectl cp .\mnt\lookerfiles ${PodName}:/mnt -n uipath -c insightslooker kubectl rollout restart statefulset insights-insightslooker -n uipathkubectl cp .\app\workdir ${PodName}:/app -n uipath -c insightslooker kubectl cp .\mnt\lookerfiles ${PodName}:/mnt -n uipath -c insightslooker kubectl rollout restart statefulset insights-insightslooker -n uipath
