- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Validate all prerequisites before starting the Automation Suite installation using the uipathctl installer.
Before starting the prerequisite validation, make sure you have downloaded the uipathctl installer to the /opt/UiPathAutomationSuite/<version> folder on all the machines, generated the cluster_config.json file, and copied the configuration file to all the machines. For instructions, refer to Downloading the installation packages and Generating cluster_config.json.
Before installing Automation Suite, it is good practice to validate the installation prerequisites and infrastructure readiness. You can use uipathctl to evaluate your environment and generate a summary before performing the installation. You can use the --verbose flag if you want to access the detailed prerequisites check output or you can skip this flag for a more concise and simplified output.
The validation of prerequisites for installing Automation Suite involves two steps:
- The first step uses
uipathctlto evaluate the installation prerequisites for Kubernetes in your environment. - The second step involves a detailed check of the prerequisites required by the shared components installation.
The following table lists all the prerequisite checks required for the Kubernetes installation.
| Validation | Description |
| Hardware requirements | Validates that each machine in the cluster meets the hardware requirements. The check takes into account the following aspects:
| Disk partitioning and configuration | Validates that you properly partitioned and configured the disk. The check takes into account the following aspects:
| SQL Server connectivity | Validates the connectivity to the configured SQL Server and database. The check takes into account the following aspects:
| Server certificate | Checks that the server certificate you provided is valid. The check takes into account the following aspects:
| Token-signing certificate | Checks that the token-signing certificate you provided is valid. The check takes into account the following aspects:
| Proxy | Validates that you properly configure the proxy. The check takes into account the following aspects:
| Connectivity | Validates that all machines can connect to each other, that all the required URLs are on the firewall allowlist, and more. The check takes into account the following aspects:
| System services | Validates that system services are properly configured. The check takes into account the following aspects:
| Software requirements | Validates that all the required software is installed. If some software is not installed, the install-uipath.sh installer attempts to install it. |
| Upgrade | Validates if the upgrade path across Automation Suite versions is correct. |
In addition to the prerequisite checks required for the Kubernetes installation, the shared components installation requires specific prerequisite checks, as listed in the following table:
| Check | Description |
| SQL Connection | Validates that Automation Suite can successfully connect to SQL server for UiPath® products and shared services (such as Identity, Portal, Org Management, etc.) using the SQL connection strings provided in cluster_config.json. This is mandatory for a successful installation. |
| SQL DB roles | Validates the necessary roles and permissions required by UiPath® products. This is mandatory for a successful installation. |
| SQL DB compatibility | Validates SQL DB compatibility requirements. |
| FQDN resolution | Validates that the FQDN and the sub-domains are successfully resolvable. |
| Object Storage API | Validates that objectstore APIs are accessible based on access information provided in cluster_config.json. This is mandatory for a successful installation of UiPath® Services. |
| Cache / Redis | Validates the connection to Cloud Redis or ElastiCache. This is mandatory for a successful installation. |
| Capacity | Validates you have minimum worker nodes' CPU and RAM capacity based on products enabled in cluster_config.json. |
| Storage Class | Validates that the storage classes for File Storage are configured as required for Automation Suite Robots. |
| Optional Components | Validates that your cluster has components that you chose to exclude from the Automation Suite installation. |
| Ingress | Validates that the cluster ingress is configured correctly and the FQDN URL requests can reach UiPath® products. |
| Network Policies | Checks if network policies configured in Automation Suite are compatible with the cluster. |
| Registry | Validates that Automation Suite can access the UiPath® docker registry. This is mandatory for a successful installation. |
| Cluster Connectivity | Validates whether the cluster communication is configured properly:
Validating the machines for the installation
To validate your machines, follow these steps:
Make sure that the RPM packages are installed and validated. For details, refer to Validating and installing the required RPM packages.
To validate the prerequisite checks for Kubernetes installation, run the following command from your installer folder (such as
/opt/UiPathAutomationSuite/<version>/installer) on each node:./bin/uipathctl rke2 prereq run cluster_config.json --node-type server \ #replace with the agent while validating the agent machine. --machines "10.0.1.8, 10.0.1.9" #replace with actual machine IPs of all the nodes in the cluster --versions versions/helm-charts.json./bin/uipathctl rke2 prereq run cluster_config.json --node-type server \ #replace with the agent while validating the agent machine. --machines "10.0.1.8, 10.0.1.9" #replace with actual machine IPs of all the nodes in the cluster --versions versions/helm-charts.jsonNote:- To validate the requirements for agent, GPU, or Automation Suite Robots machines, change the value of the
--node-typeflag fromservertoagent,gpu, orasrobots, respectively. - If you perform a single-node installation on a single machine, remove the
--machinesflag. If you perform the installation on multiple machines, provide the IP address of all the machines to validate the connectivity between them. - If you are deploying Process Mining and using Microsoft SQL Server for the
AutomationSuite_Airflowdatabase, ensure that the SQL Server machine timezone is set to UTC.
