Health endpoints
Health endpoints available for monitoring the operational status of Automation Suite services.
To effectively monitor the health of your Automation Suite services, you can use the health endpoints listed in this section. These endpoints allow you to quickly verify if a service is operating correctly.
Platform
  • https://<automation-suite-fqdn>/pap_/health
  • https://<automation-suite-fqdn>/pdp_/health
  • https://<automation-suite-fqdn>/identity_/.well-known/openid-configuration
  • https://<automation-suite-fqdn>/identity_/web/
  • https://<automation-suite-fqdn>/lease_/health/
  • https://<automation-suite-fqdn>/license_/health
  • https://<automation-suite-fqdn>/organization_/health
  • https://<automation-suite-fqdn>/portal_/portal/shallow/healthStatus
  • https://<automation-suite-fqdn>/audit_/health
  • https://<automation-suite-fqdn>/resourcecatalog_/health
Action Center
  • https://<automation-suite-fqdn>/actions_/
  • https://<automation-suite-fqdn>/bupproxyservice_/health/ready
  • https://<automation-suite-fqdn>/processes_/
AI Center
  • https://<automation-suite-fqdn>/aifabric_/ai-app
  • https://<automation-suite-fqdn>/aifabric_/ai-deployer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-trainer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-pkgmanager/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-helper/actuator/health/ready
  • https://<automation-suite-fqdn>/aistorage_/health
  • https://<automation-suite-fqdn>/<org-name>/apps_/default/api/v1/default/system-health
Automation Hub
  • https://<automation-suite-fqdn>/automationhub_/fd-api/v1/ping
  • https://<automation-suite-fqdn>/automationstore_/fd-api/v1/ping
Data Service
  • https://<automation-suite-fqdn>/dataservice_/api/HealthCheck/health
  • https://<automation-suite-fqdn>/dataservice_/assets
Document Understanding
  • https://<automation-suite-fqdn>/du_/api/documentmanager/health
  • https://<automation-suite-fqdn>/du_/api/storage/health
  • https://<automation-suite-fqdn>/du_/api/eventservice/health
  • https://<automation-suite-fqdn>/du_/metering/alive
  • https://<automation-suite-fqdn>/du_/ocr/info/ready
  • https://<automation-suite-fqdn>/du_/extended-ocr/ready
  • https://<automation-suite-fqdn>/du_/classify/MLclassification/info/ready
  • https://<automation-suite-fqdn>/du_/svc/formextractor/info
  • https://<automation-suite-fqdn>/du_/svc/intelligentkeywords/info
Insights
  • https://<automation-suite-fqdn>/insights_/health
Integration Services
  • https://<automation-suite-fqdn>/connections_/schedulerstatus
  • https://<automation-suite-fqdn>/connections_/dispatcherstatus
  • https://<automation-suite-fqdn>/elements_/v1/elements/health
  • https://<automation-suite-fqdn>/elements_/elements/api-v2/tickle
Notification Service
  • https://<automation-suite-fqdn>/notificationservice_/notificationserviceapi/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/usersubscriptionservice/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/publishermetaservice/health/readiness
Orchestrator
  • https://<automation-suite-fqdn>/orchestrator_/api/health
Robotube
  • https://<automation-suite-fqdn>/robotube_/healthz
Test Manager
  • https://<automation-suite-fqdn>/testmanager_/api/health/live
Checking service health
To check the health of a specific service, send a request to its corresponding endpoint, as shown in the following example.
curl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/health
A successful response with an HTTP status code 200 indicates that the service is healthy.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
