Seeding registry fails with DOCKER_REGISTRY_URL: unbound variable
Set DOCKER_REGISTRY_URL environment variable before seeding internal registry in Automation Suite.
When you attempt to seed the in-cluster registry using the commandseed-internal-registry command, the operation may fail with the following error message:
Solution
Set the DOCKER_REGISTRY_URL environment variable to point to the local registry address before running the command.
To address the issue, run the following command:
export DOCKER_REGISTRY_URL=localhost:<REGISTRY_NODE_PORT>
If not explicitly overridden, the default value of <REGISTRY_NODE_PORT> is 30071.
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
