- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Adding a new node to the cluster
- Removing a node from the cluster
- Repaving a cluster node
- Starting and shutting down a node
- Renaming a node
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Add server or agent nodes to an existing Automation Suite cluster to increase resourcing after installation.
You can add server and agent nodes to the deployment after installation to increase resourcing.
Adding nodes is supported in both the single-node evaluation profile and the multi-node HA-ready production profile. However, adding nodes in a single-node environment will not result in a multi-node HA-ready production environment as we do not support the transition between the two deployment profiles.
For instructions on how to download the packages required for adding a new node, refer to Downloading installation packages.
To add a new node to the cluster, take the following steps:
Configure the node to connect to the load balancer. For details, refer to Configuring the load balancer.
Download the installation packages and get them on the machines.
Copy the
cluster_config.jsonfrom an existing machines to the new one. -
Validate the prerequisites for the installation.
To add a new node, run one of the following commands:
To navigate to the installer folder, run the following commands. Replace
<version>with the actual installer version.chmod -R 755 /opt/UiPathAutomationSuite cd /opt/UiPathAutomationSuite/<version>/installerchmod -R 755 /opt/UiPathAutomationSuite cd /opt/UiPathAutomationSuite/<version>/installer -
To add a new server node, run the following commands:
./bin/uipathctl rke2 install -i ./cluster_config.json -o ./output.json -k -j server --accept-license-agreement./bin/uipathctl rke2 install -i ./cluster_config.json -o ./output.json -k -j server --accept-license-agreement -
To add a new agent node, run the following commands:
./bin/uipathctl rke2 install -i ./cluster_config.json -o ./output.json -k -j agent --accept-license-agreement./bin/uipathctl rke2 install -i ./cluster_config.json -o ./output.json -k -j agent --accept-license-agreement
To add a new GPU or Automation Suite Robots node, follow these instructions:
