How to reduce permissions for an NFS backup directory
Configure Velero backup permissions and NFS directory settings for Automation Suite.
For Velero to function, you must assign read, write, and execute permissions. The backup hook pod runs with the nobody group, so you can set the same group for Velero and the NFS directory.
You need to take the following steps to configure Velero and update the NFS directory permissions:
  1. Assign the nobody group to Velero by running the following command:
    kubectl patch deploy velero -n velero \
      --type='merge' \
      -p '{"spec":{"template":{"spec":{"securityContext":{"runAsUser":1002,"runAsGroup":65534,"fsGroup":65534}}}}}'
      --type='merge' \
    This command sets the group to nobody for Velero.
    Note:
    Reapply this command if you rerun the manifest or upgrade Velero.
  2. Change permissions on the NFS directory by running the following commands:
    chown -R nobody: /data/disk
    chmod -R 770 /datadisk/
    These commands set the directory to the nobody group and apply read, write, and execute permissions.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
