GSSAPI operation failed due to invalid status code
Solutions for GSSAPI failures due to disabled Active Directory user accounts in Automation Suite.
This log could be found when using Kerberos for SQL access, and SQL connection is failing inside services. Similarly, you may see kinit: Client's credentials have been revoked while getting initial credential in one of the following job names: services-preinstall-validations-job, kerberos-jobs-trigger, kerberos-tgt-update.
Solution
This could be caused by the AD user account used to generate the keytab being disabled. Re-enabling the AD user account should fix the issue.
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
