Migrating between Automation Suite clusters
Supported scenarios and considerations for migrating between Automation Suite cluster flavors on Linux.
About the cluster migration
You can migrate from one Automation Suite cluster to another if you use the uipath namespace instead of a custom namespace and want to move from one Automation Suite flavor to another. We support the following scenarios:
  • Migrate from Automation Suite on Linux to a new installation of Automation Suite on EKS/AKS;
  • Migrate from Automation Suite on EKS/AKS to a new installation of Automation Suite on OpenShift;
  • Migrate from Automation Suite on OpenShift to a new installation of Automation Suite on EKS/AKS;
  • Migrate from Automation Suite on EKS to Automation Suite on AKS or from Automation Suite on AKS to Automation Suite on EKS.
Note that you can attempt to perform the migration operation multiple times with no impact on your existing cluster.
The following migration scenarios are not supported:
  • Migrating from Automation Suite on Linux to an existing installation of Automation on EKS/AKS or Automation Suite on OpenShift;
  • Migrating an Automation Suite on OpenShift cluster to Automation Suite on Linux cluster.
Process overview
StepDescription
1.Mandatory. Make sure you meet the migration requirements.
2.Mandatory. Prepare the target cluster and the docker images for both source and target cluster.
Optional. If your deployment is offline or if you use a private OCI registry, make sure the required images are available.
3.Mandatory. Start the migration, move the data, and run the Automation Suite installation.
4.Optional. If AI Center is enabled on both the source and target clusters, migrate the skills.
For detailed migration instructions, refer to the Automation Suite on EKS/AKS Installation Guide.
  • About the cluster migration
  • Process overview
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
