Configuring encryption key per tenant
Reference for encryption key per tenant configuration parameters in Automation Suite.
To configure the encryption key per tenant, take the following steps:
  1. Update the Orchestrator parameters. In the configuration file, under orchestrator, add the encryption_key_per_tenant section. For details, refer to Configuring Orchestrator parameters.
    "orchestrator": {
      "enabled": true,
      "encryption_key_per_tenant": {
          "certificate_base_64": "",
          "certificate_password": "",
          "client_id": "",
          "directory_id": "",
          "vault_address": ""
    "orchestrator": {
      "enabled": true,
          "client_id": "",
          "directory_id": "",
          "vault_address": ""
    You must convert the certificate to base64 before using it as a parameter override. To do that, run the following command:
    • PowerShell
      [convert]::ToBase64String((Get-Content -path "path_to_certificate" -Encoding byte))
    • Shell
      base64 [_path_to_certificate_]
  2. Apply the new configuration, and then wait for the Orchestrator ArgoCD app to synchronize.
  3. Enable the EncryptionKeyPerTenant feature by setting the following keys in appSettings:
    "EncryptionKeyPerTenant.Enabled": "true", "EncryptionKeyPerTenant.KeyProvider": "AzureKeyVault",
    For more on updating appSettings, refer to Configuring appSettings.
    Note:
    SMTP settings in Identity Server are not encrypted with the per-tenant key. After enabling encryption key per tenant, make sure to re-enter the SMTP password in the Automation Suite portal.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
