Redis probe failure
Solutions for Redis Enterprise probe failures including shard limits in Automation Suite on Linux.
Redis probe failures can occur in the following scenarios.
Redis node ID file missing
Redis probe can fail if the node ID file does not exist. This can happen if the pod is not yet bootstrapped.
There is a recovery job that automatically fixes this issue, and the following steps should not be performed while the job is running.
When a Redis Enterprise cluster loses contact with more than half of its nodes (either because of failed nodes or network split), then the cluster stops responding to client connections. The Pods also fail to rejoin the cluster.
Redis Enterprise shard limit exceeded
Redis Enterprise may create multiple shards that exceed the license quota. This causes a domino effect where the service-rigger fails to create the required Kubernetes service for redis-cluster-db, resulting in failures for all Redis-dependent services.
Solution
  1. Disable argo sync, delete the Redis database and the Redis Cluster resource, re-enable argo sync and start a recovery job, using the following commands:
    kubectl -n argocd patch application redis-cluster --type=json -p '[{"op":"replace","path":"/spec/syncPolicy/automated/selfHeal","value":false}]'
    kubectl -n argocd patch application redis-operator --type=json -p '[{"op":"replace","path":"/spec/syncPolicy/automated/selfHeal","value":false}]'
    kubectl delete redb -n redis-system redis-cluster-db --force --grace-period=0 &
    kubectl delete rec -n redis-system redis-cluster --force --grace-period=0 &
    kubectl patch redb -n redis-system redis-cluster-db --type=json -p '[{"op":"remove","path":"/metadata/finalizers","value":"finalizer.redisenterprisedatabases.app.redislabs.com"}]'
    kubectl patch rec redis-cluster -n redis-system --type=json -p '[{"op":"remove","path":"/metadata/finalizers","value":"redbfinalizer.redisenterpriseclusters.app.redislabs.com"}]'
    kubectl -n redis-system get pods | grep services-rigger | awk '{print $1}' | xargs kubectl -n redis-system delete pod --force
    kubectl -n redis-system get pods | grep -E "redis-cluster-[0-2]" | awk '{print $1}' | xargs kubectl -n redis-system delete pod --force
    kubectl -n argocd patch application redis-cluster --type=json -p '[{"op":"replace","path":"/spec/syncPolicy/automated/selfHeal","value":true}]'
    kubectl -n argocd patch application redis-operator --type=json -p '[{"op":"replace","path":"/spec/syncPolicy/automated/selfHeal","value":true}]'
    kubectl -n redis-system create job --from=cronjob/redis-cluster-recovery-job cronjob-manual-run
  2. If the error still persists, check if there is a clock skew between the Kubernetes nodes. If any node is even a few seconds ahead or behind, the Redis pod will fail to run on it. To fix it, you must make sure all nodes have the clocks synced.
  • Description
  • Redis node ID file missing
  • Redis Enterprise shard limit exceeded
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
