- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Configuring the FQDN post-installation
- Setting up Kerberos authentication
- Forwarding logs to external tools
- Forwarding Kubernetes logs to Elasticsearch
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Reference for updating the Automation Suite FQDN post-installation via cluster_config.json and uipathctl.
To update the FQDN of Automation Suite, you must update the cluster_config.json file and run the uipathctl installer.
The FQDN update process is applicable to both single-node evaluation mode and multi-node HA-ready production mode.
Changing the FQDN requires new server certificates. If a new certificate is not available, you have two options: either continue with the new self-signed certificate configured by the installer automatically, or stop the installation and bring in a new CA-issued certificate.
You can configure the certificate via the server_certificate field in the cluster_config.json file.
Updating the config file with the new FQDN value
We support only lowercase FQDNs. Do not use uppercase characters in your FQDN.
You must update the following parameters in the input.json file. Any combination of these values is allowed, depending on your requirements.
fqdn- update this field with new FQDN that you need to access the cluster.fixed_rke_address- if this value is identical to thefqdnfield incluster_config.json, you must ensure the two values match to reflect the new FQDN. In case of Active/Passive or Active/Active setup this value must match thecluster_fqdn.cluster_fqdn- update this field for the Active/Passive or Active/Active cluster.Note:cluster_fqdnupdate is required when you change the DNS configurations at the load balancer level for any of the clusters
The following example shows the cluster_config.json configuration required to update the FQDN.
"fqdn": "new-automationsuite.mycompany.com" //this is the fqdn for accessing the automation suite cluster
"fixed_rke2_address": "new-automationsuite.mycompany.com,"//this is only required for the node joining, if customer wish to change "cluster_fqdn": "new-primary-automationsuite.mycompany.com" //this is only required for the a/p or a/a cluster
Step 1: Updating FQDN at the infrastructure level
To update the FQDN at infrastructure layer, run the installer only on the the first server machine. This will update all the other nodes in the cluster, including the remaining server nodes, agent nodes, and specialized agent nodes.
To update the FQDN, run the following command:
./bin/uipathctl rke2 update-fqdn -i /path/to/cluster_config.json --versions versions/helm-charts.json
If you run the command with the --force flag, it will override the warning prompts and perform the FQDN changes directly.
The installer warns you of the consequences of updating the FQDN. It asks for confirmation before proceeding.
[WARN] You are about to change the FQDN of the Automation Suite Cluster.
Changing the fqdn is a disruptive operation, and it will result in
disconnecting your robots, mobile orchestrator users, ML Activities,
and ML Skills and invalidating any pending user invites.
If you wish to continue type 'yes' and hit enter to continue.
Step 2: Enabling maintenance mode
Before triggering the FQDN update at the components and services level, you must enable maintenance mode. This shuts down the ingress controller and all the UiPath® services, blocking all the incoming traffic to the Automation Suite cluster.
To put the cluster in maintenance mode, run:
./bin/uipathctl cluster maintenance enable
To verify that the cluster is in maintenance mode, run:
./bin/uipathctl cluster maintenance is-enabled
Step 3: Updating FQDN at the components and services level
./bin/uipathctl manifest apply /path/to/cluster_config.json --versions versions/helm-charts.json
The installer also warns you if there is no new valid certificate related to the FQDN. If the certificate validation fails, the installer requires you to provide the new CA-issued certificate or continue with the new self-signed certificate.
[ERROR] Validating certificate... Failed
[ERROR] Certificate doesn't have new-automationsuite.mycompany.com in the SAN
Certificate provided is invalid for the new fqdn, would you like us to configure the new self signed certificate?
If you wish to continue type `yes` and hit enter to continue.
Make sure to clear all the data from your Redis database. You can do this by running the FLUSHALL command.
Step 4: Disabling maintenance mode
After updating the FQDN, disable maintenance mode to restore traffic to the Automation Suite cluster.
To disable maintenance mode, run:
./bin/uipathctl cluster maintenance disable
For details, refer to uipathctl cluster maintenance disable.
Updating FQDN in an Active/Active deployment
If you change the FQDN of the primary cluster in an Active/Active setup, you need to take the following additional steps:
Enable maintenance mode on the primary cluster:
./bin/uipathctl cluster maintenance enable./bin/uipathctl cluster maintenance enable -
Generate a new kubeconfig for the primary cluster.
Add the new kubeconfig in the
cluster_config.jsonof the secondary cluster, underother_kube_config. -
On the secondary cluster, run the following command:
uipathctl manifest apply cluster_config.json --versions versions/helm-charts.jsonuipathctl manifest apply cluster_config.json --versions versions/helm-charts.json -
Disable maintenance mode on the primary cluster:
./bin/uipathctl cluster maintenance disable./bin/uipathctl cluster maintenance disableFor details, refer to uipathctl cluster maintenance disable.
