Database configuration
Reference for database creation workflow and sql.create_db parameter behavior in Automation Suite installations.
Database creation workflow
The interactive installer automatically creates databases using the following workflow:
  1. The interactive installer script checks the value of the sql.create_db parameter in the cluster_config.json file.
    • If the sql.create_db parameter is set to true, the installer automatically generates all the databases on your behalf. In this case, the installer uses the default database names and default templates, and ignores any custom database names you provided.
    • If sql.create_db is set to false, you must bring your own databases. In this case, you must manually set up your databases. Note that you can use custom database names, provided that you follow the provided naming conventions. This step is critical because we use the database name in conjunction with the connection template to form the database connection string. If you do not follow the recommended naming convention, you must provide the SQL connection strings yourself.
      For details, refer to Bring your own databases.
  2. The interactive installer generates the connection strings as follows:
    • If you did not define a connection string for your service, the installer uses the connection template to generate all database connection strings.
    • If you defined a connection string for your service, the installer uses the provided connection string for your database.
Automatically create the necessary databases
If you want the installer to create the databases, fill in the following fields of the cluster_config.json file:
ParameterDescription
sql.create_dbSet to true to allow the installer to create the databases. Note that the installer uses the default database names and default templates, and ignores any custom database names you provided.
sql.server_urlFQDN of the SQL server, where you want the installer to configure database.
sql.portPort number on which a database instance should be hosted in the SQL server.
sql.usernameUsername / user ID to connect to the SQL server.
sql.passwordPassword of the username provided earlier to connect to the SQL server.
Note:
  • Ensure the user has the dbcreator role. This grants them permission to create the database in SQL Server. Otherwise, the installation fails.
  • Automatically creating the necessary databases does not work in combination with directory authentication. If you use directory authentication, you must bring your own databases.
  • ODBC connection does not support usernames that contain special characters. For database usernames for AI Center, Document Understanding, and Apps, use only uppercase and lowercase letters.
Important:
For Process Mining on Automation Suite, you need to manually create the PostgreSQL database for AutomationSuite_Airflow before installing or upgrading to Automation Suite 2.2510 or higher. The PostgreSQL database for Airflow will not be created automatically by the installer.
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
If you bring your own database, you must provide the SQL connection strings for every database. Automation Suite supports the following SQL connection string formats:
Note:
For Document Understanding, make sure that you are using the same database, unless otherwise explicitly stated. Specific connection strings are assigned to various services and jobs that connect to the same database.
Connection string templates
ParameterDescriptionProducts
sql_connection_string_templateFull ADO.NET connection string where Catalog name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.Platform
Orchestrator
Automation Suite Robots
Test Manager
Automation Hub
Automation Ops
Insights
Integration Service
Studio Web
Data Service
Process Mining
LLM Gateway
LLM Observability
ECS
Solutions
sql_connection_string_template_jdbcFull JDBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.AI Center 1
Integration Service
sql_connection_string_template_odbcFull ODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.Document Understanding
Apps
Integration Service
sql_connection_string_template_sqlalchemy_pyodbcFull SQL alchemy PYODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.Document Understanding
postgresql_connection_string_template_sqlalchemy_pyodbcFull SQL alchemy PSYCOPG2 connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.Process Mining
1 To install AI Center on a FIPS 140-2-enabled machine, you must append the following to sql_connection_string_template_jdbc: encrypt=true;trustServerCertificate=false;fips=true;.
Make sure the SQL account specified in the connection strings is granted the db_owner role for all Automation Suite databases. If security restrictions do not allow the use of db_owner, then the SQL account should have the following roles and permissions on all databases:
  • db_securityadmin
  • db_ddladmin
  • db_datawriter
  • db_datareader
  • EXECUTE permission on dbo, dt, authz, and msgbus schema
We only use the db_securityadmin and db_ddladmin roles during installation or if the databases are reprovisioned, so you may revoke these permission afterwards. Insights requires the db_owner role to be assigned for a successful installation.
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, ODBC, or PYODBC passwords as follows:
  • for SQL: add ' at the beginning and end of the password, and double any other '.
  • for JDBC/ODBC: add { at the beginning of the password and } at the end, and double any other }.
  • for PYODBC: username and password should be url encoded to account for special characters. Document Understanding database passwords cannot start with {.
The AutomationSuite_ProcessMining_Airflow database for Process Mining product must have READ_COMMITTED_SNAPSHOT enabled.
By default, TrustServerCertificate is set to False, and you must provide an additional CA certificate for the SQL Server. This is required if the SQL Server certificate is self-signed or signed by an internal CA. If you do not provide the SQL Server certificate in this scenario, the prerequisite check will fail. For details, refer to Certificate configuration on this page.
The following example shows a sql_connection_string_template connection string:
Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net:1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;
Note:
The User Id value in the connection string is case-sensitive.
The following example shows a sql_connection_string_template_jdbc connection string:
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
The following example shows a sql_connection_string_template_odbc connection string:
SERVER=sfdev1804627-c83f074b-sql.database.windows.net,1433;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD=***;MultipleActiveResultSets=False;Encrypt=YES;TrustServerCertificate=NO;Connection Timeout=30;"
The following example shows a sql_connection_string_template_sqlalchemy_pyodbc connection string:
mssql+pyodbc://testuser%40sfdev3082457-sql.database.windows.net:_-%29X07_%5E3-%28%3B%25e-T@sfdev3082457-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
The following example shows a postgresql_connection_string_template_sqlalchemy_pyodbc connection string for Process Mining:
postgresql+psycopg2://<user>:<password>@<host>:<port>/DB_NAME_PLACEHOLDER
Process Mining combined templates
The following examples show combined template configurations for Process Mining:
"sql_connection_string_template": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='07<l[xj-=~:z`Ds&nl';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
"postgresql_connection_string_template_sqlalchemy_pyodbc ":
"postgresql+psycopg2://<user>:<password>@sfdev4515230-postgresql.database.windows.net:5432/DB_NAME_PLACEHOLDER"
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
Default database names
The following example shows the default and optional DB names for Automation Suite services:
  "orchestrator": "AutomationSuite_Orchestrator",
  "orchestrator_ta": "AutomationSuite_Orchestrator",
  "asrobots": "AutomationSuite_Orchestrator",
  "orchestrator_upd": "AutomationSuite_Platform",
  "platform": "AutomationSuite_Platform",
  "test_manager": "AutomationSuite_Test_Manager",
  "automation_ops": "AutomationSuite_Platform",
  "automation_hub": "AutomationSuite_Automation_Hub",
  "insights": "AutomationSuite_Insights",
  "integrationservices": "AutomationSuite_Integration_Services",
  "dataservice": "AutomationSuite_DataService",
  "aicenter": "AutomationSuite_AICenter",
  "documentunderstanding": "AutomationSuite_DU_Datamanager",
  "processmining_airflow": "AutomationSuite_Airflow",
  "processmining_metadata": "AutomationSuite_ProcessMining_Metadata",
  "processmining_warehouse": "AutomationSuite_ProcessMining_Warehouse",
  "apps": "AutomationSuite_Apps",
  "automationsolutions": "AutomationSuite_AutomationSolutions",
Note:
If you want to override the connection string for any of the mentioned services, set the sql_connection_str for that specific service.
You still have to manually create these databases before running the installer.
Product-specific connection string overrides
To override the database connection strings for other products, set the sql_connection_str in the corresponding product blocks. The connection string should have a format supported by the respective product.
Orchestrator and platform
The following example shows how to override the default connection string for Orchestrator and the platform:
  "orchestrator": {
    "sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=CustomOrchDB;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
  "platform": {
    "sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=CustomIDDB;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
  "orchestrator": {
  "platform": {
AI Center
The following table describes the cluster_config.json parameter for setting the AI Center database connection string.
aicenter.sql_connection_strAI Center JDBC connection string
Note:
Make sure the JDBC connection string has the format in the following sample:
The following example shows a sample AI Center connection string:
"aicenter": {
    "enabled": true,
    "sql_connection_str": "jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net;database=aicenter;user=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;password=TFgID_9GsE7_P@srCQp0WemXX_euHQZJ"
"aicenter": {
    "enabled": true,
The following example shows a sample Document Understanding connection string:
"documentunderstanding": {
        "enabled": true,
        "sql_connection_str": "Server=SERVER_PLACEHOLDER;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=USER_PLACEHOLDER;Password='PASSWORD_PLACEHOLDER';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
        "datamanager": {
            "sql_connection_str": "SERVER=SERVER_PLACEHOLDER;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=USER_PLACEHOLDER;PWD={PASSWORD_PLACEHOLDER};;Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=customer-sql.database.windows.net",
            "pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sql.database.windows.net:Z%3Aw%21%zE%3Cb4@sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
        "enabled": true,
        "datamanager": {
Note:
The data manager SQL connection string is optional only if you want to overwrite the default with your own.
Process Mining
Process Mining connection strings have the following differences from template connection strings:
  • The template connection string names (postgresql_connection_string_template_sqlalchemy_pyodbc for PostgreSQL and sql_connection_string_template) differ from the bring-your-own-database names (sqlalchemy_pyodbc_sql_connection_str and sql_connection_str).
  • If you bring your own database and configure it using sql_connection_str and sqlalchemy_pyodbc_sql_connection_str in the processmining section of cluster_config.json, the template connection strings sql_connection_string_template and postgresql_connection_string_template_sqlalchemy_pyodbc are ignored.
The app_security_mode setting controls how SQL users are created for Process Mining apps. In the default app_security_mode="system_managed" mode, a new SQL user is created for every Process Mining app, which requires advanced permissions for the database user. In app_security_mode="single_account" mode, a single SQL user account is used for all process apps. For details, refer to Configuring process app security.
If you use a Multi-AZ with Always On SQL setup, set MultiSubnetFailover=True for sql_connection_str and master_sql_connection_str, and MultiSubnetFailover=Yes for sqlalchemy_pyodbc_sql_connection_str. Note that for pyodbc you use =Yes instead of =True.
For Kerberos authentication, use the Integrated Security and Trusted_Connection parameters instead of a username and password. Set Integrated Security to true and Trusted_Connection to yes to authenticate using the credentials of the currently logged in user.
Connection string examples
The following example shows a sample Process Mining connection string (PostgreSQL):
  "processmining": {
    "enabled": true,
    "app_security_mode": "system_managed",
    "airflow": {
      "metadata_db_connection_str": "postgresql+psycopg2://testadmin:<password>@sfdev8454496-postgresql.postgres.database.azure.com:5432/AutomationSuite_Airflow"
    "warehouse": {
      "sql_connection_str": "Server=tcp:kerberossql.autosuitead.local,1433;Initial Catalog=AutomationSuite_Warehouse;Persist Security Info=False;User Id=testadmin;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
      "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://testadmin:<password>@kerberossql.autosuitead.local:1433/AutomationSuite_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES",
      "master_sql_connection_str": "Server=tcp:kerberossql.autosuitead.local,1433;Initial Catalog=master;Persist Security Info=False;User Id=testadmin;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
    "sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='password';Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
  "processmining": {
    "enabled": true,
    "airflow": {
    "warehouse": {
The following example shows a Process Mining connection string for a setup with Kerberos authentication (PostgreSQL):
"processmining": {
    "enabled": true,
    "airflow": {
      "metadata_db_connection_str": "postgresql+psycopg2://kerberos_user:@kerberospostgres.AUTOSUITEAD.LOCAL:5432/automationsuite_airflow"
    "warehouse": {
        "sql_connection_str": "Server=tcp:assql2019.autosuitead.local,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
        "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes",
        "master_sql_connection_str": "Server=tcp:assql2019.autosuitead.local,1433;Initial Catalog=master;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
"processmining": {
    "enabled": true,
    "airflow": {
    "warehouse": {
The following example shows a Process Mining connection string for a setup where the metadata database and data warehouse use a separate SQL server (non-Kerberos authentication):
"processmining": {
    "enabled": true,
    "warehouse": {
      "sql_connection_str": "Server=tcp:uipath-integration1.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
      "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://userid:password@uipath-integration1.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES",
      "master_sql_connection_str": "Server=tcp:uipath-integration1.database.windows.net,1433;Initial Catalog=master;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
  "airflow": {
    "sql_connection_str": "Server=tcp:uipath-integration2.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"processmining": {
    "enabled": true,
    "warehouse": {
  "airflow": {
The following example shows a Process Mining connection string for a setup using custom app_security_mode:
"processmining": {
    "enabled": true,
    "warehouse": {
   "airflow": {
"processmining": {
    "enabled": true,
    "warehouse": {
   "airflow": {
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
