- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Exploring Logs
- Exploring summarized telemetry
Last updated Dec 23, 2025
During an RKE2 upgrade, the newly installed
snapshot-controller conflicts with the pre-existing snapshot-controller. As a result, the installation pod for snapshot-controller-crds enters a CrashLoopBackOff state.
To fix this issue, take the following steps:
Update the
/etc/rancher/rke2/config.yamlfile with the following details on all server nodes:disable: - rke2-ingress-nginx - rke2-snapshot-controller - rke2-snapshot-controller-crd - rke2-snapshot-validation-webhookdisable: - rke2-ingress-nginx - rke2-snapshot-controller - rke2-snapshot-controller-crd - rke2-snapshot-validation-webhook -
Restart the
rke2-serverusing the following command:systemctl restart rke2-server.servicesystemctl restart rke2-server.service -
Run the following commands to clean up the existing snapshot controller pods:
to clean up the
snapshot-controller-crdinstallation job:kubectl delete jobs -n kube-system helm-delete-rke2-snapshot-controller-crd --ignore-not-foundkubectl delete jobs -n kube-system helm-delete-rke2-snapshot-controller-crd --ignore-not-found -
to clean up the
snapshot-controllerinstallation job:kubectl delete jobs -n kube-system helm-install-rke2-snapshot-controller --ignore-not-foundkubectl delete jobs -n kube-system helm-install-rke2-snapshot-controller --ignore-not-found -
to clean up the
snapshot-controllerdeployments:kubectl delete deploy -n kube-system snapshot-controller, rke2-snapshot-controller --ignore-not-foundkubectl delete deploy -n kube-system snapshot-controller, rke2-snapshot-controller --ignore-not-found
