- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Preparing the new cluster
- Migrating the data to the new cluster
- Completing the upgrade
- Scaling up the target cluster
- Instant rollback on failure
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Scale single-node target cluster to multi-node HA configuration after side-by-side upgrade.
This step is applicable only when you are following the Side-by-side upgrade (single node start).
To scale up the target cluster, follow these steps:
Perform sanity check on the single node target cluster. Make sure it is functional and the migrated data is intact.
Check the Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment page for the detailed steps on converting a single-node deployment to a multi-node setup. To reduce the infra requirements, you can clean the nodes from the source cluster and add it to the target cluster one by one. Do not dismantle all the nodes of source cluster at once.
For removing the nodes from the source cluster, check the How to uninstall the cluster page. Before you proceed with the uninstallation of Kubernetes, ensure you delete the node from the cluster using
kubectl delete node.The nodes set to join the target cluster must be clean and should not contain any data corresponding to the old cluster.
Note:If you are removing the nodes from source cluster and joining to the target cluster, it is strongly recommended to create a backup of the source cluster and the SQL database before the scale up. This is to ensure you can restore the source cluster if something goes wrong while scaling up the target cluster.
After converting the target cluster to HA setup, you can retain the same FQDN as the source cluster or update the FQDN. After updating the FQDN, switch the traffic to the new cluster.
- Before updating FQDN, you must add the required certificates to match the FQDN.
- To update the FQDN, refer to the Configuring the FQDN post-installation page.
Note:Changing the FQDN also requires new server certificates. If a new certificate is available, you have two options: either continue with the new self-signed certificates configured by the installer automatically, or stop the installation and bring in a new certificate.
You can configure the certificate via the
server_certificatefield incluster_config.json. -
In case of failure or issues during the side-by-side upgrade process, you can instantly roll back to your previous state by disabling maintenance mode on your source cluster by following the Instant rollback on failure page. If you have decommissioned any nodes from source cluster, you can add them back by following the Adding a new node to the cluster page.
Enable the backup on the cluster target.
