Installation best practices
Follow best practices to ensure a reliable and uninterrupted installation process in Automation Suite.
To avoid your SSH session getting interrupted, we recommend initiating a tmux session and then running the installation process in the context of that session. If run under the tmux session, the SSH session can be interrupted, and you can reconnect to the previous session from where the installer was initiated.
Take the following steps:
  1. SSH into the remote machine.
  2. Install tmux on the machine using the following command:
    sudo yum install tmux
  3. Create a tmux session by running the following command.
    tmux new -s uipath_install
  4. Once inside tmux, you can start the installation process.
    • Commands such as the following one run in the session.
      ./installUiPathAS.sh
      ./bin/uipathctl rke2 install -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -k -j server --offline-bundle ./as-infra.tar.gz --offline-tmp-folder /var/tmp --install-offline-prereqs --accept-license-agreement
    • To list all sessions, run the following command:
      tmux ls
      tmux ls
    • To connect to most recent session, run the following command:
      tmux a
      tmux a
    • To connect to a session by name, run the following command:
      tmux attach -t uipath_install
  5. To leave or detach from the tmux session, press Ctrl+B and then press D.
To reattach a tmux session, take the following steps:
  1. List the sessions:
    tmux ls
    tmux ls
  2. Find the appropriate tmux session and attach it to resume from the last working state:
    tmux attach -t <session-name>
Avoiding VM snapshot performance issues
When running Automation Suite on virtual machines hosted on VMware ESXi or other on-premises hypervisors, active snapshots and their delta files can degrade disk I/O throughput. Components with high I/O requirements, such as etcd, are particularly susceptible and may become unstable under this load.
To reduce the risk of snapshot-related I/O issues:
  • Stagger snapshot timing so that snapshots for each VM are not taken simultaneously.
  • Use the underlying storage array's native snapshot feature instead of hypervisor-level snapshots.
  • Delete snapshot delta files immediately after the snapshot is no longer needed.
  • On VMware: use VMware Virtual Volumes (vVols) instead of VMware Virtual Machine File System (VMFS) datastores.
Important:
These mitigations apply to any hypervisor snapshot technology that introduces delta files, not only VMware.
  • Avoiding VM snapshot performance issues
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
