- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Monitoring capabilities in Automation Suite, including Prometheus, Grafana, and Alertmanager integration.
Automation Suite includes pre-configured Prometheus, Grafana, and Alert manager components by default, offering:
- Ready-to-use dashboards
- Out-of-the-box alert rules
- Integrated logs and metrics for core components
Alternatively, you can export metrics to your own monitoring tools. For details, refer to External monitoring tools.
For a list of components that you can monitor, refer to Deployment architecture.
Using the monitoring stack
Node failures might lead to a Kubernetes shutdown, which would disrupt Prometheus alerts. To prevent this, we recommend setting up a separate alert on the RKE2 server.
- You must configure alert receivers to prevent any issues that may lead to downtime.
- You can refer to dashboards for regular monitoring.
- You can refer to logs for troubleshooting.
Accessing the monitoring tools
You can access the Automation Suite monitoring tools individually using the following URLs:
| Application | Tool | URL | Example |
| Metrics | Prometheus | https://monitoring.fqdn/metrics | https://monitoring.automationsuite.mycompany.com/metrics |
| Dashboard | Grafana | https://monitoring.fqdn/grafana | https://monitoring.automationsuite.mycompany.com/grafana |
| Alert Management | Alert Manager | https://monitoring.fqdn/alertmanager | https://monitoring.automationsuite.mycompany.com/alertmanager |
For details on how to fetch Grafana credentials, refer to the Accessing Grafana dashboard section.
If you have excluded the built-in monitoring components, the related tools and URLs will not be available. For details, refer to Optional: Configuring the monitoring solution.
Monitoring tool authentication
To access the monitoring tools for the first time, log in as an admin with the following default credentials:
Username: admin
Password: to retrieve the password , run the following command:
kubectl get secrets/dex-static-credential -n uipath -o "jsonpath={.data['password']}" | base64 --decodekubectl get secrets/dex-static-credential -n uipath -o "jsonpath={.data['password']}" | base64 --decode
Dex authentication
To update the default password used for Dex authentication while accessing the monitoring tools, take the following steps.
Dex is a basic authentication method layered over the monitoring tools. Therefore, updating the Dex password does not impact the passwords for the monitoring tools. In this scenario, the passwords for the monitoring tools remain the same as before.
Run the following command by replacing
newpasswordwith your new password:password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]"password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]" -
Run the following command to update the password:
./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json
Integrating external monitoring tools
If your organization prefers to use a centralized observability platform (such as Datadog, ELK, New Relic), you can disable the built-in monitoring components during installation by updating the cluster_config.json configuration file. For details, refer to Optional: Configuring the monitoring solution.
Exporting critical metrics
When you use an external monitoring solution, certain critical platform metrics, such as certificate expiry, must be collected and monitored to maintain platform reliability and security.
To support this, Automation Suite deploys Pushgateway even when built-in monitoring is excluded. Pushgateway pushes important metrics at regular intervals so that external systems can scrape them and generate alerts.
Internal platform jobs collect certificate and license expiry data and send it to Pushgateway. Your external Prometheus instance can then scrape the endpoint and trigger alerts as needed.
The following critical metrics are available through Pushgateway for external monitoring:
| Metric name | Description |
rke2-cert-expiry | Number of days until RKE2 node or server certificates expire. |
tls-cert-expiry | Number of days until TLS certificates in Kubernetes secrets expire. |
redis-license-expiry | Number of days until the Redis Enterprise license expires. |
signing-certificate-expires-30 | Indicates that an identity signing certificate expires in 30 days. |
signing-certificate-expires-7 | Indicates that an identity signing certificate expires in 7 days. |
The following example shows the tls-cert-expiry metric when scraped by Prometheus:
tls_cert_expiry {
certname="ca.crt",
instance="",
job="tls-cert-expiry",
ns="istio-system",
secret="istio-ingressgateway-certs"
} 10
tls_cert_expiry {
certname="ca.crt",
instance="",
ns="istio-system",
} 10
In this example, the certificate ca.crt in namespace istio-system, stored in secret istio-ingressgateway-certs, expires in 10 days.
