- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- AI Center skills deployment issues
- Enabling AI Center on the restored cluster
- Exploring Logs
Solutions for Document Understanding model skill deployment failures in AI Center, including retry and service restart procedures.
Sometimes intermittently DU Model Skill Deployments can fail with Failed to list deployment or Unknown Error when deploying the model for the first time. The workaround is to try deploying the model again. Second time, it will be faster as most of the deployment work of image building would have been done during the first attempt. DU Models takes around 1-1.5 hours for deploying first time, and it will be faster when deploying them again.
In a rare scenario, due to cluster state, asynchronous operations like Skill Deployment or Package upload could be stuck for a long time. If DU Skill deployment is taking more than 2-3 hours, try deploying a simpler model (e.g, TemplateModel). If the model also takes more than an hour, then the mitigation is to restart AI Center services with the following commands:
kubectl -n uipath rollout restart deployment ai-deployer-deployment
kubectl -n uipath rollout restart deployment ai-trainer-deployment
kubectl -n uipath rollout restart deployment ai-pkgmanager-deployment
kubectl -n uipath rollout restart deployment ai-helper-deployment
kubectl -n uipath rollout restart deployment ai-appmanager-deployment
Wait for the AI Center pods to be back up by verifying with the following command:
kubectl -n uipath get pods | grep ai-*
All the pods should be Running state with container state shown as 2/2.
