- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Hardware and software requirements for Automation Suite deployments, covering node specs, product selections, and cluster sizing.
Terminology
To find out more about the core concepts used in an Automation Suite deployment, refer to Glossary.
Product selection
The default installation experience includes a choice of two product selections:
Complete (All products) - Install the complete list of products available in Automation Suite. For details, refer to Automation Suite products.
Select products - Allows you to select and install only the products you are interested in. Note, however, that the installer takes the cross-product dependencies into consideration. That means that if a product requires the installation of another product, you must install both of them. For details, refer to Automation Suite products.
Note:You can enable additional products later in the same deployment at any point in time, after the initial installation, without having to reinstall. For details, refer to Managing products.
We recommend validating the hardware requirements based on expected usage and ensuring the deployment has enough capacity before adding additional products. For details, refer to Capacity planning.
Choose your deployment profile
You can deploy Automation Suite in single-node, lite mode, or multi-node HA-ready production mode. While most of the prerequisites for the profiles are identical, multi-node HA-ready production mode requires additional resources.
Once the deployment is completed, changing the deployment profile is generally limited. However, single-node deployments can be scaled to multi-node high availability (HA) deployments, and lite deployments can be expanded to multi-node HA-ready deployments. Before choosing your deployment profile, refer to Deployment modes and use cases.
Linux and Kubernetes knowledge is required regardless of the deployment profile you choose. If you encounter issues installing and configuring Automation Suite, contact UiPath® Professional Services.
Prerequisites at a glance
| Prerequisite type | Prerequisite |
| Hardware |
To avoid potential installation issues, make sure that all nodes used in the deployment are set to the same time zone. |
| General machine requirements | |
| Requirements specific to the following products:
| Supported RHEL version and ipcalc tool installed on all the Linux machines.For details about RHEL compatibility with previous Automation Suite versions, refer to RHEL compatibility matrix .
We support new minor versions of RHEL within 90 days of their release. We support SELinux with default policies. * | |
| FIPS 140-2 | |
| Load balancer L4 / Network Load Balancer | |
| NFS server requirement (on-premises or cloud-managed NFS server with NFSv3/NFSv4 version on Linux based)
| Node ports | |
| Software | RPM packages on each machine |
| SQL Server | |
| Objectstore (Azure Blob storage, AWS S3, S3 compatible objectstore) | |
| OCI-compliant registry | |
| DNS | |
| TLS 1.2 or higher | |
| IPv4, IPv6, and dual-stack | |
| Swap memory must be disabled. | |
*For air-gapped installations, the rke2-selinux package is not installed automatically. If you experience SELinux-related issues, you must install the SELinux policy package manually. For details, refer to the How to... section.
- You need root permission to install and deploy Automation Suite. For more on the specific components that require root access, refer to Root privileges requirement.
- Cilium requires CAP_SYS_ADMIN permissions to function correctly. Make sure these permissions are granted.
- Having scan agents running on your system may cause installation or runtime failures, due to the changes they make to the IPTables. To avoid this behavior, configure your scan agent so that it does not interfere with the Automation Suite installation.
- UiPath® does not prescribe specific firewall or developer tool configurations as long as the Automation Suite requirements are met. Based on our observations, a limited number of external tools can interfere with the smooth operation of Automation Suite. If such issues arise, contact the relevant vendor for help. For additional guidance, refer to the Automation Suite responsibility matrix.
Hardware requirements
Before you begin, consider the following:
Automation Suite supports Federal Information Processing Standard 140-2 (FIPS 140-2). You can perform a clean installation of Automation Suite on a FIPS 140-2-enabled host. You can also enable FIPS 140-2 on a machine where you previously performed an Automation Suite installation. For details, refer to Security and compliance.
Note:Insights is currently not supported on FIPS-enabled hosts. Make sure to disable Insights when installing Automation Suite on a FIPS-enabled host.
The minimum hardware requirements do not protect the deployment from node failures.
The multi-node HA-ready production profile is resilient to only one node failure. This means that you can lose only one server node. This restriction does not apply to agent nodes. You can lose as many agent nodes and still continue to use the cluster without downtime as long as enough overall cluster capacity is available.
You can increase the server node tolerance to failure by following the instructions in Advanced installation experience.
The following sections list out the hardware requirements for both the complete product selection and individual products.
Complete product selection: hardware requirements
The following sections describe the hard requirements for the complete product selection.
General requirements
| Hardware for all products | Single-node minimum requirement | Multi-node minimum requirements |
| Processor per cluster | 32 (v-)CPU/cores | 96 (v-)CPU/cores |
| Minimum processor per node | N/A | 8 (v-)CPU/cores |
| RAM | 64 GB | 192 GB |
| Minimum RAM per node | N/A | 16 GB |
| Cluster disks* | 256 GB SSD Min IOPS: 1100 | 256 GB SSD Min IOPS: 1100 |
| Data disk
| 512 GB SSD Min IOPS: 1100 | 512 GB SSD Min IOPS: 1100 |
| etcd disk
| 16 GB SSD Min IOPS: 240 | 16 GB SSD Min IOPS: 240 |
| UiPath® bundle disk
| Objectstore
| Additional disk space for Ceph data backups
| 512 GB SSD Min IOPS: 1100 | N/A |
| AI Center | 51 GB minimum 105 GB recommended for 1 training pipeline | 51 GB minimum 105 GB recommended for 1 training pipeline |
- The following considerations apply to cluster disk capacity:
- You may need to increase cluster disk capacity based on your AI Center ML skills and training storage requirements.
- If you enable Document Understanding modern projects, the minimum cluster disk capacity is 512 GB.
If you install Automation Suite in single-node evaluation mode, and you do not have a machine with 32 (v-)CPU/cores and 64 GB of RAM, you can bring machines with a minimum of 8 (v-)CPU/cores and 16 GB of RAM. For details, refer to Capacity calculator.
If you choose this option, follow the multi-node installation and configuration instructions.
It is recommended to bring external objectstore whenever possible. This helps in scaling the objectstore independently of the cluster, and brings additional stability. We support the following objectstore options:
- Azure storage account
- AWS S3 storage bucket
- S3 compatible storage bucket
Individual products: hardware requirements
For details on the hardware requirements your must meet to install individual products or various product combinations in Automation Suite, use the Automation Suite Install Sizing Calculator.
Additional Automation Suite Robots requirements
In multi-node HA-ready production environments, Automation Suite Robots require an additional agent node. In single-node evaluation environments, an additional Automation Suite Robots node is optional.
The hardware requirements for the Automation Suite Robots node depend on the way you plan to use your resources. In addition to the additional agent node requirements, you also need a minimum of 10 GB of file storage to enable package caching.
The following sections describe the factors that impact the amount of hardware the Automation Suite Robots node requires.
Robot size
The following table describes the required CPU, memory, and storage for all robot sizes.
| Size | CPU | Memory | Storage |
| Small | 0.5 | 1 GB | 1 GB |
| Standard | 1 | 2 GB | 2 GB |
| Medium | 2 | 4 GB | 4 GB |
| Large | 6 | 10 GB | 10 GB |
Agent node size
The resources of the Automation Suite Robots agent node have an impact on the number of jobs that can be run concurrently. The reason is that the number of CPU cores and the amount of RAM capacity are divided by the CPU/memory requirements of the job.
For example, a node with 16 CPUs and 32 GB of RAM would be able to run any of the following:
- 32 Small jobs
- 16 Standard jobs
- 8 Medium jobs
- 2 Large jobs
Job sizes can be mixed, so at any given moment, the same node could run a combination of jobs, such as the following:
- 10 Small jobs (consuming 5 CPUs and 10 GB of memory)
- 4 Standard jobs (consuming 4 CPUs and 8 GB of memory)
- 3 Medium jobs (consuming 6 CPUs and 12 GB of memory)
Kubernetes resource consumption
Given that the node is part of a Kubernetes cluster, the Kubernetes agent present on the server (kubelet) consumes a small amount of resources. Based on our measurements, the kubelet consumes the following resources:
- 0.6 CPU
- 0.4 GB RAM
A node similar to the one previously described would actually have approximately 15.4 CPUs and 31.6 GB of RAM.
Automatic machine size selection
All your cross-platform processes have the Automation Suite Robots option set to Automatic by default. This setting selects the appropriate machine size for running the process using serverless robots.
When automatically choosing the size, the criteria listed in the following table are evaluated in order. As soon as one criterion is satisfied, the corresponding machine size is chosen and the remaining criteria are not evaluated.
| Order | Criterion | Machine size |
| 1 | Remote debugging job | Medium |
| 2 | Process depends on UI Automation OR Process depends on the UiPath Document Understanding activities | Standard |
| 3 | Other unattended process | Small |
Additional AI Center and Document Understanding requirements
On top of the core service requirements that are part of full platform requirements, AI Center requires additional resources, depending on the models that you want to run or train. For details about the required GPU hardware generations and compatible NVIDIA drivers, refer to Compatibility Matrix.
AI Center requires disk storage at runtime for the ML Skills and for the training pipeline, as follows:
- The ML Skills require disk space on the
/var/lib/rancherpartition for storing the trained model for predictions. In the worst case scenario, the model size can be as big as 20 GB. - The training pipeline consumes the storage from the
/var/lib/rancherpartition for hosting the model. In the worst case scenario, the model size can be as big as 20 GB, and additionaly, it can require storage for the dataset. The minimum size of the dataset storage can be 51 GB. The recommended size is 105 GB. This must be on the dedicated disk for AI Center. The training pipeline only schedules on the node on which the dedicated AI Center disk is attached.
The following table describes the additional resources AI Center needs. In the following table, Data Disk is needed on all server nodes. Data Disk is not needed on agent nodes.
| Use | CPU | RAM (GB) | GPU | Disk (GB) |
| Minimum for serving (ML Skill, one replica) | 0.6 | 2 | 0 | 20 GB on the rancher partition |
| Minimum for Training (Pipeline) | 1 | 4 | 0 | 20 GB on the rancher partitionMinimum 51 GB AI Center disk partition (recommended 105 GB) |
| DU model Serving (ML Skill, one replica) | 1 | 4 | 0 | 20 GB on the rancher partition |
| DU model Training | 2 | 24 | Strongly recommended | 20 GB on the rancher partitionMinimum 51 GB Data Disk (recommended 105 GB) |
The following table describes the required resources for small and average AI Center implementations. Note that these numbers are general guidance.
| Small implementation :
| 4 | 32 | 0 |
| Average implementation :
| 8 | 52 | Strongly recommended |
1 (3 skills +1 pipeline) * 20 GB on the rancher partition = 80 GB on the rancher partition
2 1 pipeline * 105GB = 105 Data disk
3 (5 skills + 2 pipeline + 1 DU pipeline) * 20 GB on the rancher partition = 160 GB on the rancher partition
4 (2 pipeline + 1 DU pipeline) * 105GB = 315 Data disk
Additional AI Computer Vision requirements
This setup works on on-premises Nvidia GPUs, but also works with cloud providers such as AWS, Azure and GCP. Suggested GPU types include those from the RTX, Tesla, and Ampere family of products which have enough GPU memory and processing capability.
The main difference between these two types of GPUs is that the ones with virtualization usually have more GPU RAM and are offered by most cloud providers. Having more GPU RAM increases the maximum size of the image you can input to the model. In conclusion, virtualization GPUs are not significantly faster that the consumer GPUs.
You need a machine with the following hardware specifications:
| Hardware specification | Minimum | Recommended |
| Memory | 8 GB | 16 GB |
| CPU | 2 cores with AVX2 enabled | 4 cores with AVX2 enabled |
| GPU | 8 GB VRAM | 16 GB VRAM |
| Storage | 30 GB free | — |
Additional Document Understanding recommendations
For increased performance, you can install Document Understanding on an additional agent node with GPU support. Note, however, that AI Center-based projects in Document Understanding are fully functional without the GPU node. Actually, Document Understanding uses CPU VMs for all its extraction and classification tasks, while for OCR we strongly recommend the usage of a GPU VM.
For details about the CPU/GPU usage within the Document Understanding framework, refer to CPU and GPU Usage.
If you want to use an additional node with GPU support, you must meet the following requirements:
| Hardware | Minimum requirement |
| Processor | 8 (v-)CPU/cores with AVX2 support |
| RAM | 52 GB |
| OS disk | 256 GB SSD Min IOPS: 1100 |
| Data disk | N/A |
| GPU RAM | 11 GB |
For details, refer to the AI Center considerations section.
Additional Document Understanding modern projects requirements
With CPU inference activated, a minimum of 2 GPUs is required. To enable CPU inference, set the enable_cpu_inference property to true, as indicated in the Enabling or disabling Document Understanding section.
- Inference may be up to 10 times slower.
- We recommend using it for documents with a maximum of 125 pages. No active limitation is in place. However, inference might fail for documents larger than 125 pages.
Without CPU inference, a minimum of 5 GPUs is required for Document Understanding modern projects. The example scenario in the following table demonstrates how 5 GPUs is enough to process 300 pages.
For Document Understanding modern projects, the minimum recommended GPU is NVIDIA T4.
The following table lists the capacity functions and the number of operations supported per GPU node.
| Function | Number |
| Custom model pages processed per hour | 300 |
| Out of the box model pages processed per hour | 0 |
| Models training in parallel | 1 |
| Number of pages in all projects - Design time | 200 |
| Number of document types per project version | 3 |
The 5 GPUs are distributed amongst different functions, as detailed in the following table:
| Service | Number of GPUs |
| OCR replicas | 1 |
| Custom model training replicas | 1 |
| Custom model replicas | 2 |
| Out of the box model replicas | 1 |
| Total | 5 |
For details on how to allocate GPUs to each service, refer to the Allocating GPU resources for Document Understanding modern projects page.
In addition to the GPU demands, Document Understanding modern projects also require specific CPU resources for optimal performance. For optimal performance, a minimum of 18 vCPUs is required.
With the modern Document Understanding project, an additional 4 TB of the objectstore is required to perform the activities from the provided examples continuously for one year. You can start with a smaller number, but the activity will fail once the storage is complete, unless you explicitly scale it.
If you are provisioning for one year of continuous processing, you will need 4 TB for Document Understanding modern projects and 512 GB for the other products. The total will be 4.5 TB of storage. Similarly, if you start with six months of processing, you will need 2 TB for Document Understanding modern projects and 512 GB for the other products. In this case the total will be 2.5 TB.
For more detailed calculations and the capacity required for your needs, check the UiPath Automation Suite Install Sizing Calculator.
Provisioning MIG-enabled GPUs
Automation Suite Document Understanding workloads support running on Virtual GPUs (VGPUs) created with NVIDIA MIG (Multi-Instance GPU) technology.
To run Document Understanding in these conditions, keep in mind the following requirements:
- GPU memory (VRAM): at least 16 GB per VGPU. UiPath only supports the single strategy, meaning that all VGPUs will be exactly the same.
- Storage: at least 80 GB per VGPU
Enabling MIG-enabled GPUs in Kubernetes
After provisioning the MIG enabled GPUs in your cluster with profiles matching or exceeding the above minimum requirements, ensure that the GPUs are schedulable Kubernetes. The node must report a non-zero number of GPUs before workloads can be scheduled on it.
To make the GPUs schedulable, follow the official documentation for installing the device plugin.
Alternatively, you can manually apply the device plugin to your gpu nodes to get started.
Apply the following configuration, replacing migEnabledPoolName with the label that matches your GPU node:
apiVersion: v1
kind: Pod
metadata:
namespace: gpu-resources
spec:
affinity:
nodeAffinity:
requiredDuringSchedulingIgnoredDuringExecution:
nodeSelectorTerms:
- matchExpressions:
- key: agentpool
operator: In
values:
# To be changed to a selector that matches the GPU nodes
- migEnabledPoolName
containers:
- args:
- --fail-on-init-error=false
env:
- name: MPS_ROOT
value: /run/nvidia/mps
- name: MIG_STRATEGY
# We only support the single strategy for now
value: single
- name: NVIDIA_MIG_MONITOR_DEVICES
value: all
- name: NVIDIA_VISIBLE_DEVICES
value: all
- name: NVIDIA_DRIVER_CAPABILITIES
value: compute,utility
image: nvcr.io/nvidia/k8s-device-plugin:v0.17.3
imagePullPolicy: IfNotPresent
securityContext:
allowPrivilegeEscalation: true
capabilities:
add:
- SYS_ADMIN
terminationMessagePath: /dev/termination-log
terminationMessagePolicy: File
volumeMounts:
- mountPath: /var/lib/kubelet/device-plugins
tolerations:
- key: CriticalAddonsOnly
operator: Exists
- effect: NoSchedule
key: nvidia.com/gpu
operator: Exists
terminationGracePeriodSeconds: 30
volumes:
- hostPath:
path: /var/lib/kubelet/device-plugins
type: ""
apiVersion: v1
kind: Pod
metadata:
spec:
affinity:
nodeAffinity:
nodeSelectorTerms:
- matchExpressions:
- key: agentpool
operator: In
values:
containers:
- args:
env:
- name: MPS_ROOT
value: single
value: all
value: all
securityContext:
capabilities:
add:
- SYS_ADMIN
volumeMounts:
tolerations:
operator: Exists
key: nvidia.com/gpu
operator: Exists
volumes:
- hostPath:
type: ""
After deploying the plugin, the node's Allocatable section should show the correct number of VGPUs under nvidia.com/gpu, based on the MIG profile you configured. The node should now be schedulable and ready to run Document Understanding workloads.
RPM package requirements
Before starting the Automation Suite installation, you must ensure you meet the following requirements:
- you have a RHEL subscription
- you enabled the BaseOS and AppStream repositories
- you installed the required RPM packages
The following table lists the required RPM packages:
| RPM package | Description |
iscsi-initiator-utils nfs-utils rpcbind util-linux nmap-ncat openssl httpd-tools gettext zstd | Required on nodes for installation. |
podman>=4.0.2 nmap-ncat bind-utils openssl wget unzip conmon=>2.0.24 | Required on nodes for the execution of the readiness check. |
iscsi-initiator-utils gettext nfs-utils rpcbind util-linux nmap-ncat openssl httpd-tools podman=>4.0.2 zstd | Required for offline installations only. |
RHEL 8.4 and later have the required RPM packages in the BaseOS and AppStream repositories by default.
Manual installations
If you perform a manual clean installation of Automation Suite, you must ensure you meet the RPM package requirements. In this case, you are responsible for installing the required RPM packages.
If you upgrade from a previous Automation Suite version, you have already installed the RPM packages.
For details on the tools you can use to install and validate RPM packages, refer to Validating and installing the required RPM packages.
Cloud templates
If you install Automation Suite using our Azure, AWS, or GCP templates, no action is needed from your side. The templates provision the full infrastructure, including the RPM packages.
Microsoft SQL Server general requirements
Unless otherwise specified in the dedicated requirements sections, these requirements are applicable to all Automation Suite products.
- Automation Suite versions 2.2510.0 and higher are compatible with SQL versions 2019 and higher.
- When you enable Process Mining for installation on Automation Suite must bring a PostgreSQL database for
AutomationSuite_Airflow. Check out SQL requirements for Process Mining for details.
Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
Make sure that the SQL server can be accessed from each cluster VM.
Individual product support varies.
For each product you plan to deploy, you must:
- check the supported version of SQL Server as required by the product
- apply the SQL Server configuration prerequisites, including SQL Server User permission, as required by the product For details on product-specific SQL Server requirements, refer to Configuring Microsoft SQL Server.
The general minimum hardware requirements for Microsoft SQL Server are as follows:
- 8 (v-)CPU
- 32 GB RAM
- 256 GB SSD
These minimum requirements are general guidance and do not guarantee reliable operation in a production deployment. Capacity planning is required to determine the hardware requirements that are needed for reliable operation.
For each product you plan to deploy, you must evaluate projected usage and apply the capacity planning guidance as specified by the product. This information is available in the help section of each individual product.
NFS Server general requirements
To enable a backup, you need an external NFS server. Automation Suite supports Linux-based on-premises or cloud-managed NFS servers, version NFSv3/NFSv4.
The NFS server must be production-ready and actively maintained. Using a non-production or unsupported NFS server can cause downtime for every service that depends on it, and can lead to data loss or corrupted data.
Make sure that the NFS server can be accessed from each cluster VM.
The general minimum hardware requirements for NFS Server are as follows:
- CPU - 4 vCPU
- RAM - 8 GB
- Storage - 1 TB
Note:
If you use an external objectstore, the storage requirement is a few GBs. If you use an in-cluster objectstore, the minimum storage size is the same as the size of the objectstore.
Disaster recovery - Active/Passive requirements
To configure an Active/Passive deployment, make sure you meet the following requirements:
- Hardware
- Load balancers
- DNS
- Certificates
- Objectstore
- Traffic Manager
Hardware
Both Automation Suite clusters must meet a set of software and hardware requirements. For details, refer to the hardware requirements for the multi-node mode.
Load balancer
Both Automation Suite clusters must have a load balancer. For details, refer to Configuring the Load balancer.
DNS
For details of the DNS requirements, refer to Configuring the DNS.
Certificates
For details of the certificate requirements, refer to Certificate requirements.
You must also add the SANs to the certificate if you opened the DNS.
Objectstore
In-cluster objectstore is not supported while deploying Automation Suite in multi-site. Instead, you must bring an external objectstore.
Automation Suite uses Rancher for RKE2 support on RHEL, so only the RHEL versions listed below are officially supported. Unlisted versions within the same major line (8.x or 9.x) may install and run, but UiPath cannot guarantee support if issues arise. Deploy only on a listed RHEL version for full support.
The following table lists the RHEL versions supported by each version of Automation Suite:
| Automation Suite version | Supported RHEL versions |
| 2.2510.4 | 9.7, 9.8, 10.0, 10.2 |
| 2.2510.3 | 8.8, 8.9, 8.10, 9.2, 9.4, 9.5, 9.6, 9.7, 10.0 |
| 2.2510.2 | 8.8, 8.9, 8.10, 9.2, 9.4, 9.5, 9.6, 9.7, 10.0 |
| 2.2510.1 | 8.8, 8.9, 8.10, 9.2, 9.4, 9.5, 9.6, 9.7 |
| 2.2510.0 | 8.8, 8.9, 8.10, 9.2, 9.4, 9.5, 9.6, 9.7 |
Starting with Automation Suite 2.2510.2, host nodes must run cgroup v2. If your environment uses cgroup v1 (the default on RHEL 8.x), you must migrate to cgroup v2 before upgrading. For migration instructions, refer to How to migrate to cgroup v2.
This requirement is enforced using the fail-cgroup-v1 kubelet flag, which will be deprecated in upcoming RKE2 versions. We recommend upgrading to cgroup v2 as soon as possible, either before or after upgrading to 2.2510.2.
RHEL kernel versionkernel-4.18.0-477.10.1.el8_8 is affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses this kernel version either pre- or post-installation.
RHEL 10 considerations
RHEL 10.1 is not supported. We identified a performance issue with RHEL 10.1 that significantly slows down database file saving and causes RKE service crashes.
If you use RHEL 10, consider the following:
RHEL 10 includes the cockpit web console installed by default, which listens on port 9090. This conflicts with Cilium used by Automation Suite. To resolve this conflict, either configure the cockpit web console to listen on a different port, or disable it using the following commands:
systemctl disable --now cockpit.socket systemctl daemon-reloadsystemctl disable --now cockpit.socket systemctl daemon-reload -
GPU kernel modules are no longer included in the RHEL 10 repositories by default. To install GPU drivers, install the packages separately by running
dnf install cuda-drivers. We have tested thekernel-develandkernel-headersGPU packages with kernel version6.12.0-55.43.1.el10_0.
- Terminology
- Product selection
- Choose your deployment profile
- Prerequisites at a glance
- Hardware requirements
- Complete product selection: hardware requirements
- Individual products: hardware requirements
- RPM package requirements
- Manual installations
- Cloud templates
- Microsoft SQL Server general requirements
- NFS Server general requirements
- Disaster recovery - Active/Passive requirements
- Hardware
- Load balancer
- DNS
- Certificates
- Objectstore
- RHEL compatibility matrix
- RHEL 10 considerations
