- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to reduce permissions for an NFS backup directory
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to recover Kerberos authentication after a VM restart
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- Upgrade failure due to uppercase hostname
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Fluentd does not export logs in IPv6 environments
- Exploring Logs
Reference for additional backup and restore configuration options in Automation Suite, including NFS server guidance.
Repaving or updating the NFS server
UiPath® does not provide any specific steps to repave or update the NFS server.
Before updating the NFS server, make sure the backup is disabled. For instructions, refer to Backing up the cluster.
Guidelines
It is good practice to back up the disk attached to the NFS server where you create the backup. You can find this information defined as the
nfs.mountpointkey in thebackup.jsonfile. -
To repave the NFS server, take the following steps:
- Mount the backup disk on the newly repaved machine on the same mount point as defined by the
nfs.mountpointkey in thebackup.jsonfile. - Update the NFS endpoint of the new NFS server defined as
nfs.endpointinbackup.json. - After repaving the NFS server, make sure you have followed the Setting up the external NFS server guidance.
Once the update to NFS server is complete, it is recommended to reboot the machine. Also make sure to enable the backup on cluster. For instructions, refer to Backing up the cluster.
Adding a new node to the cluster
To add a new node to the cluster, re-run the following steps:
- Add the FQDN or the IP address of the new node to the allowlist of the NFS server. For instructions, refer to Allowing NFS mount path access to all backup and restore nodes.
- Enable the backup on the new node post-installation. For instructions, refer to Backing up the cluster.
Using a local disk backup
When backups are stored on a locally attached disk in a single server node of the Backup Cluster, you must manually detach and reattach that disk to the Restore Cluster before you can restore data.
You need to complete this process carefully to avoid disk conflicts and ensure a clean transition between clusters.
- On the backup cluster, take the following steps:
Connect to the backup cluster server node.
ssh <backup-cluster-node>ssh <backup-cluster-node> -
Unmount the backup disk.
umount /backupumount /backup -
Detach the backup disk from the virtual machine. The following is an Azure example:
az vm disk detach \ --resource-group "${resource_group_name}" \ --vm-name "${node_name}" \ --name "server0-CephBackupDisk"az vm disk detach \ --resource-group "${resource_group_name}" \ --vm-name "${node_name}" \ --name "server0-CephBackupDisk"
- On the restore cluster, take the following steps:
Connect to the restore cluster server node.
ssh <restore-cluster-node>ssh <restore-cluster-node> -
Attach and mount the backup disk. The following is an Azure example:
az vm disk attach \ --resource-group "${resource_group_name}" \ --vm-name "${node_name}" \ --name "server0-CephBackupDisk"az vm disk attach \ --resource-group "${resource_group_name}" \ --vm-name "${node_name}" \ --name "server0-CephBackupDisk" -
If
/backupis currently mounted, unmount it.umount /backupumount /backup -
Remove any existing
/backupentry from/etc/fstab.sed -i.bak '/\/backup/d' /etc/fstabsed -i.bak '/\/backup/d' /etc/fstab -
Identify the newly attached disk.
lsblklsblkLocate the unmounted disk name (for example,
/dev/sdX). -
Rescan physical volumes.
pvscanpvscan -
Rename the volume group (VG) on the attached disk.
vg_uuid=$(pvs --noheadings -o vg_uuid /dev/sdX | awk '{print $1}') vgrename "$vg_uuid" backupvg_restoredvg_uuid=$(pvs --noheadings -o vg_uuid /dev/sdX | awk '{print $1}') vgrename "$vg_uuid" backupvg_restored -
Activate the renamed volume group.
vgchange -ay backupvg_restoredvgchange -ay backupvg_restored -
Ensure the mount directory exists.
mkdir -p /backupmkdir -p /backup -
Mount the logical volume.
mount /dev/backupvg_restored/backuplv /backupmount /dev/backupvg_restored/backuplv /backup -
Add a persistent entry in
/etc/fstab.echo '/dev/backupvg_restored/backuplv /backup xfs defaults 0 0' >> /etc/fstabecho '/dev/backupvg_restored/backuplv /backup xfs defaults 0 0' >> /etc/fstab
After you complete the procedure, you need to verify that the backup disk is correctly mounted and that the backup data is accessible on the restore cluster.
Take the following steps to confirm that the configuration is valid:
Verify that the
/backupmount point is active.df -h /backupdf -h /backup -
Confirm that backup data is accessible under
/backup. -
Proceed with restore operations as needed.
- Always make sure that no active write operations are occurring on
/backupbefore you detach the disk. - If you are using a non-Azure environment, replace the disk attach and detach commands with the equivalent commands for your platform (for example, AWS
aws ec2 detach-volume). - Renaming the volume group (
vgrename) prevents name conflicts between clusters.
